Thread: another 1.9 cdti with problems
    lincolnshire
    Angry another 1.9 cdti with problems
    driving down the road and the engine loses all power for a few seconds then will go fine again
    so got home had a look and the bar on the inlet manifold that connects to the swirl valve has come off again
    so im guessing its a manifold change?
    main dealer only?
    thanks folks
    South Yorkshire
    Had mine done in September. Cost me £913. Parts only £290 (for inlet manifold and Swirl Valve as they must be changed together) but labour was 6 hours worth.
    I would get the steelers to check the EGR valve and the injector wiring loom whilst there at it, especially if your cars still under warranty.
    lincolnshire
    unfortunately the car is 2004 and out of warranty
    im fairly handy when it comes to mending cars but im not up to speed with these high pressure injection jobbies so it might be a trip to VX
    lincolnshire
    while i was out in the garage i thought id clean the egr valve and it was solid with corrosion
    also noticed the inside of the manifold where the egr bolts was bunged up too so cleaned it up
    just the manifold to get done and it should finally be runing well once again
  1. 1.9 cdti few problems
    By Daz1987 in forum Engine & Drivetrain
    Last Post: 23rd February 2013, 20:24
  2. 1.9 CDTI Problems
    By kai21 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th March 2011, 11:27
  3. 150 cdti problems
    By zymon in forum Engine & Drivetrain
    Last Post: 5th March 2011, 12:40
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  5. Problems with V6 CDTI
    By phil0464 in forum Engine & Drivetrain
    Last Post: 23rd April 2009, 23:08
