hi can anyone tell me if i remove my cd70 radio will i need the code when install it back? cheers mitch
should just plug in and play away mate as it is part of the CANbus network on the car, and already linked straight through....
Midlands Mod Shop - NFFC.
If your car is full canbus and you taking it out and putting it back in the same car then no. If you are taking it out to put in another car then it will need to be tech2'd out and tech2'd into the new car. You will need the car passes for both cars to do this.
If it is half canbus then you will need a code which should be on your car pass. U use the code to put it into another half canbus car or back into the same car.
i just got tools today, to remove the radio to see if got loom behind it for heated seat switches as not long put leather in it. so i dont need code if going back in same car? cheers lads![]()
oh by the way its an 07 plate, so that would be full canbus wouldnt it?
Yes full Canbus, I've had the CDC40 out of mine (56 plate) on numerous ocassions with no problem
