Is this a big thing? my vectra elite is a 2.2 2002 model. with 128k miles
now ive been asked if its been changed or not as someone was told by an RAC that after a 120k the crankshaft sensor will go.
any ideas?
any ideas?
Why worry. In my opinion do not fix what aint broke. The sensor COULD pack in next week or next year, leave it till it breaks.
3.2 v6 Signum and loving it 😁
wish I had a crankshaft
ive never done a crank shaft sensor on a 2.2 petrol.... dont fix what isnt broke you may give yourself more problems than you need ........
are these likely to go though, someone is suggesting that because my vectra has done 128k miles its life is pretty much up soon. They have a bmw 528i on 168k mile and suggesting that the bmw engine would last till 400k
They can go at any time m8..symptoms are car wont start /fire up.no need to pre empt it going as generally last indefinatly..ie i had a Rover 214 many moons ago..only done 12k and it went..but known cars do 150k and they are fine..
A crankshaft sensor or cam sensor (in fact any sensor) is a component.
If it fails, it fails. If it doesn't, then leave it alone.
Some components fail, some don't. The majority will be in a car cradle to grave!
The only component that I know of that has been programmed to fail after a finite number of uses is an ignitor module on a certain make of domesitc boiler. A certain manufacturer designs them to fail after 1 million ignition cycles.
all i will say is i have never changed or even know of any one changeing the crank sensor on a 2.2 ...i think some people get the older 1.8 2.0 and the v6 engines confused they were very very bad for the sensors failing ......
