Thread: Think i need new wheel bearing
    Cambridgeshire
    Unhappy Think i need new wheel bearing
    The car is making humming/growling noises and it's coming from the rear offside wheel. It gets louder when i'm coming to a stop (when braking). It's not so loud when moving but now that i'm listening for it i can hear it.
    I diagnosed it so far as a wheel bearing. Anybody else got any thoughts?
    If it is the bearing how much am i looking at do you think?
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    check your tyre mate its a common problem for the tyres to make the noise of a bearing gone
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Easy to check, jack up the car a nd see if there is any movement in the bearing. Move the road well form left to right and then from top to bottom if you see what i mean. Also spin the wheel and see if it runs free or makes a noise
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    have u checked your brake discs and pads mine where the same as yours when i fitted new discs and pads all was well.hth
    Cambridgeshire
    I thought the Vec-c's have pad wear sensors? Or is that just for the front brakes?
    Cheers the for advice so far guys. I've gotta get it jacked up sometime and check it out.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by parsco View Post
    Only for the front pads
    Cambridgeshire
    Quote Originally Posted by wanna veccy View Post
    Very good, tell him what he's won
    Just got it diagnosed today. My mate who owns a garage checked it over and said the back discs and pads are pretty much shot. (One side on the back has no pad left at all ) He said that the fronts will need replacing soon, i'm going to hold off and gather some money together after xmas and get the 314mm upgrade. He's going to change the rear discs and pads for £110 (parts and labour )
    Cheers for the help guys
    Cambridgeshire
    I got the rear discs and pads changed this evening. Then drove it home, obviously. Didn't drive it very far but when i was pulling into the drive and braking i heard the noise again, only not so load. Does this mean the noise may have been coming from the front brakes? I'm hoping that i just need to change the front brakes and nothing else. How would i know if it was something like a brake servo or a wheel bearing?
    Can anybody assure me that is all i will need to do to get rid of this noise? (Sounds like a scratching / grinding noise when braking, whilst moving slowly / coming to a stop)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well you needed the rear brakes doing as they were danagerous to say the least from what you said. Did your mate check the front ones as well?
    Cambridgeshire
    He said the front ones have a lip but will last a little while if i want to get hold of some 314's. I just concerned that i could spend near £300 for a set of upgraded brakes and find that there is still something wrong
  1. UJ or wheel bearing?
    By Endricks in forum Engine & Drivetrain
    Last Post: 8th April 2012, 10:49
  2. Wheel Bearing ?
    By jer75 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2011, 02:01
  3. wheel bearing
    By stuart bigboy in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2007, 17:07
  4. Wheel Bearing with VX?
    Last Post: 6th March 2007, 00:19
