Thread: Reversing sensors
    Chester
    Question Reversing sensors
    Hi all
    I am going to be brave and fit some parking sensors to my 2007 sri on Saturday and have researched all the how 2s and am reasonably confident on most of it. However, there seems to be a difference of opinion regarding the wiring i.e. through a relay or not. Obviously wiring direct to the reversing light is easier but I am concerned that this may cause problems with warning lights etc.
    Any comments on either wiring option would be greatly appreciated.
    Sunny Dartmoor
    Relay is not needed m8,just fit a £15-25 kit from ebay thats what i've done and loads of other members,good luck......
    The reason for the bypass is so that if you ever use the 'Light your way home' feature where the headlights and reversing lights come on the reversing sensors aren't activated and start beeping away.
    If that doesn't bother you then you can just tap off the reversing light wiring - although for the small extra effort to add the bypass you may as well.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    I added mine to the reversing light (on my previous sri).. as Duncan says they go on with the light home thing, but only beep once (unless you then walk past them on the way to your door).
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    what do u mean by bypass me not that electrically minded
    Chester
    Thanks for the swift advice, I think I know what i'm doing now. I never use the "light your way home feature" anyway so no problem there.
    Sunny Dartmoor
    Quote Originally Posted by wanna veccy View Post
    Fitting a relay.......
    A bypass switch - it's a switch that will only give power to the sensors (when wired from the reverse light wiring) if the ignition is on.
    Nov 2007
    telford,
    all u doing is fitting a switch , is this right so all u doing is turning them on when u want them on insted of them just coming on automatically.
    No, it's an automatic type of switch. As long as it has power into it from an ignition live feed then it will allow power to go through to the sensors from the reverse light wiring feed. When the ignition is on the switch will allow power through to the sensors and they will work automatically when reverse is selected.
    As glenboy said it's like a relay - in fact I think it's actually called a bypass relay as opposed to bypass switch which I'd referred to it as. A relay is a switch at the end of the day but a relay is probably more descriptive.
  1. reversing sensors
    By redo in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 19:27
  2. reversing sensors
    By markj23 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2011, 21:10
  3. reversing sensors HELP PLEASE
    By SRIRob in forum Styling
    Last Post: 20th January 2010, 14:43
  4. Reversing sensors
    By d16wal in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2008, 00:48
  5. which reversing sensors please?
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 21:48
