Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Wet passenger side rear foot well.
    Hampshire
    confused Wet passenger side rear foot well.
    Hi all, hope someone can offer some help.
    The carpet in the rear passenger side foot well of my 52 plate Vectra C is wet. Not just wet, soaked!!! I have tried having the heating on full (and set to blow down), scooping the water out and even been down to local petrol station and used their vacuum to suck out the water. Result, dry for about a day and then soaked again. I happens if it is raining or dry.
    Back in July I suffered the flooding due to the drainage hole under the pollen filter being blocked, this soaked the Passenger Foot well, which I dried out, but didn't think of drying the rear (don't ask why, I just didn't think of it).
    I don't know whether the water in the rear passenger foot well is water from that flooding or not. I expect it is not as I can dry it out and the next day it is soaked again (unless there is an area under the rear carpet which is acting as a reservoir).
    I have checked under the skuttle at both ends and everything is dry, I have taken out the glove box and everything is dry behind there. The Trim around the rear door is dry so I don't think it is coming in from there, which from what I can see leaves only two possible places for the water to come from. These are:
    The air blower under the passenger seat.
    Or the condensation pipe from the air con (this is a real stab in the dark as I don't know where this is located, although I exepct that this is probably towards the front of the car).
    I have noticed that the pollen filter is missing from the car, but looking at the air inlet I don't see any way that rain would get in there, the vent in the skuttle is too far to the right for the rain to get directly in (I think), and based on other threads i have read it seems like water coming in that way always floods the front passenger foot well, not the rear.
    Looking at the wet marks in the carpet I think that the water is coming from under the passenger seat as the sides (trim, center console and seat) are all dry apart from the bottom 20mm or so.
    I've run out of anything else to try, so any help or suggestions are very much appreciated.
    Thanks in advance.
    Trev
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Hampshire
    Quote Originally Posted by Stevie-B View Post
    Thanks for that. I had read it previously but assumed that it was referring to the front passenger foot well, not the rear.
    If it is the Rear, what Water Gutter and Water Drainage Compartment do you think it is referring to?
    Thanks again.
    Trev
    Mar 2007
    NI
    Sorry Trev, did'nt read the post in full. Still maybe worth sending her in to get the door seals looked at....
    Hampshire
    I've just ordered a Pollen filter, if that doesn't help then I guess it's the door seals. It just seems odd that the wettest part is under the Passenger seat, not by the door. Also that it happens even it it hasn't been raining.
    Mar 2007
    NI
    That's very odd..... I change my pollen filter every 2 years, hav'nt really seen much of a difference and I can't imagine pools of water coming from it being worn.....
    But hey stranger things have happened. Take a few pics and post here and keep a record of the weather conditions etc... build up a profile and then talk to VX H.Q technical services or better still a bodywork specialist..... just a thought.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Use a hose pipe to direct water around the car exterior and have a good look to see if it comes in anywhere. I may narrow it down a bit.
    Hampshire
    The Pollen filter isn't worn... it isn't there at all, just a big open sace with a fan at the bottom!!!
    New one turned up today, so have fitted it, will see what happens!
    Hampshire
    Quote Originally Posted by Ste View Post
    I think that may be my next thing to try... just got to find a very long hose!!!
    Mar 2007
    NI
    Quote Originally Posted by TrevF View Post
    Again apologies for not reading.... NO POLLEN FILTER.... yes that is gonna cause a problem.... Don't know about letting water in the cabin though..... may help.....
    Let us know how you got on...
  1. Wet Passenger Side at Foot area
    By akeem in forum Bodywork & Interior
    Last Post: 9th November 2012, 10:29
  2. Gsi passenger side rear exhaust box
    By larrysSRI in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd September 2012, 21:55
  3. Vec 57 - Front and rear passenger foot well damp!
    By preecy in forum Bodywork & Interior
    Last Post: 23rd July 2012, 14:34
  4. Vec 3.2...water on passenger side foot thing...
    By vec3.2 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2009, 09:16
