Thread: Is the 2.2 engine in the Vec C the same as the one in the Vec B?
    Regular Member ROY GBIV's Avatar
    The highways and byways
    Default Is the 2.2 engine in the Vec C the same as the one in the Vec B?
    The 2.2 petrol engine, Is it the same unit, prone to timing chain failure?
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    The 2.2 in the Vectra C should have the newer oil jet nozzle as mine did on a 2002 reg (52 plate). The early Vectra C engine is the same as the Vectra B, then a bit later the engine changes for the direct Z22YH engine.
    Regular Member david.aka.judas's Avatar
    Suffolk
    dont knock the z22se engine.........drool
    happy days...lol
    Full Member Big Sig's Avatar
    Although a few did have the "bad" jets, they seemed to slip through the net. Benny - user on here - knows much more about it.
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    i believe the z22se was given a new lease of life in 2001 when vx had the prone parts upgraded to beter quality parts.
    Regular Member mark_w's Avatar
    cheshire
    early and later 2.2 engines discussed here -
    http://www.vectra-c.com/forum/showthread.php?t=61861
    Regular Member Mick B's Avatar
    North East
    Quote Originally Posted by wanna veccy View Post
    Mine is a 53 plate and my jet was the smaller type ;( Got it changed before it caused problems so year means nothing . Vauxhall said the chain\jet issues were resolved in the C but it seems it wasn't the case.
    Nov 2007
    telford,
    that'll be vx for ya m8 like it says in an earlier thread the timing chain issues should have been resolved in 2001.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
