Thread: HID vs headlight (it's dark out there).
    Belfast
    Default HID vs headlight (it's dark out there).
    Had my HIDs fitted for about a month with no problems. Tonight came out of work, no passenger side headlight working, check bulb warning on.
    So, checked all connections, no go.
    Ripped HID out, replaced standard bulb in headlight - still no light but check bulb has cleared.
    The other side continues to work 100%.
    Checked the 10A fuse under the bonnet, it's intact.
    All other lights in the lighting unit work OK.
    Is it likely a failed HID unit has cooked something, or are there other fuses elsewhere in the car?
    Driving both ways to work in the dark, I'm really hoping this is a simple fix.
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Try disconnecting the battery for a couple of mins, it seemed to fix mine when it did the same.
    Belfast
    I'll try that in the morning pricey, if it doesn't reset itself overnight. I'd hate to have to set my clock/radio/etc all again.
    If you just take it off for a few seconds then it won't loose the clock or radio settings, or at least mine didn't on Sunday.
    Belfast
    Well, got it going again, popped out the 10A fuse for the lights, and it's working again.
    So, 1 normal headlight bulb and 1 HID on the other side at the moment until I can get either a new HID kit or can source decent halogens.
    Regular Member Craig1985's Avatar
    harwich essex
    Quote Originally Posted by _ZS_ View Post
    My HID ballast pack packed up after 7 months. just sent a polite email to
    the CAR MOD SHOP on EBAY and he sent me one out straight away. couldnt belive it! highly recommend them to anyone in future
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Most HiD kit sellers offer a 12 month (+) guarantee anyway, so _ZS_ dependant on when you got the kit, you should be able to get a replacement part no worries - its usually the ballast that fails.
    Belfast
    Yeah, the ballast is dead short. It's also totally ancient, got them over 3 years ago so they don't owe me much.
    Probably go for a new kit, standard bulbs are a bit poo. Well, 1 standard bulb and 1 HID at the moment.
  1. Going dark
    By bobssignum in forum Styling
    Last Post: 10th June 2012, 21:25
  2. help! it's dark in my car!!!
    By Yvanovicz in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2012, 23:59
  3. DARK sri. reg: R10 OBT
    By Vectra-c-SRI in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 26th November 2010, 15:24
