Thread: TC fuse location?
    West
    Default TC fuse location?
    My 2.0dti has tc & no switch, which was all fine until we hit the snow this morning...
    I have never had a problem driving through the snow, until today...
    The TC would not let the car do any thing, very embarrasing too...
    Can some one tell me the location of the fuse for next time i'm stuck in an inch of ****** snow...
    Cheers!
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Its a pain in the ass i got stuck in the mud out side mine i just had to keep putting it in 1st then reverse to get it rocking finnaly got out after destroying the grass
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Fuse box under bonnet, between battery and n/s wing. fuse #7 (20amp,yellow) - according to owners manual "Central control unit, ESP,TC".
    Hope this helps.
    EDIT - manual also mentions fuse #13 (also under bonnet, 20amp, yellow) - "Central control unit, ESP,TC".
    Now I'm confused......
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Will taking the fuse out not disable your ABS or ESP if you have it, as TC is linked to ABS is it not?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by john_k_sri View Post
    ABS fuses, according to the manual, are again under the bonnet and are refered to as #16 (7.5A) and #29 (40A).
    Guess dh.dti only wants to get the car going and out of the **** and then refit fuse once clear
    West
    Quote Originally Posted by Sean-2.2Direct View Post
    lol...
    Quote Originally Posted by gtr1000 View Post
    Hope this helps.
    Thanks, i will look at both & see...
    Yes it probably will, but I'm not looking to drive around all day with it disabled, just to get me out of the snow onto the main road...
    It will be in the fuse box in the engine bay.
    As John said it will also disable the ABS - although not really an issue if all you want to do is get out of the snow. On the 2.0T removing the fuse kills the engine - it simply won't start or will die if it's running - so I don't know what effect it will have on the 2.0DTi. I know on other engines you can pull it with no problem, just not sure about the DTi.
    West
    Will give it a go & take it from there, cheers!
  1. boot fuse location and number ( if possible)
    By valhalla in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2012, 14:27
  2. N/s low beam fuse location
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 15:23
  3. Fuse box location on vectra b.help please.
    By felixx in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2010, 21:17
  4. fuse location
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2009, 16:57
  5. Steering wheel fuse location
    By Stuarty in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2009, 21:12
abs fuse on 2005 vectra 2.2 direct
vectra c traction control fuse
esp fuse vectra c
vectra c abs fuse location
Vectra tcs fuse
vectra c 2.0 dti fuse diagram
zafira b turn off esp fuse
esp fuse opel signum
zafira disable traction control
fuse for abs on vectra c 1.9
vectra-B tc fuse location
zafira dti tc
thermostat fuse location vectra c
opel vectra c esp fuse
vectra c cdti the traction control fuse
vectra c tc and abs fuse
opel zaffirra 2.2 esp system
vectra c TC fuse diagram
location fusehed opel vectra c 2.0 dti
vauxhall astra 2.0 dti abs fuse
https:www.vectra-c.comforumshowthread.php63578-TC-fuse-location
signum 2.0 turbo esp fuse
