Thread: Vectra 2.2 sri hid kit fitting
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Vectra 2.2 sri hid kit fitting
    hello, did anybody else out there have any problems fitting the off side control unit as the air box was in the way as its shaped to fit the inner wing?????????????
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Depends what kit you've got,if it's a single box ballast you can bolt it to the slam panel above the h/light or to the crash can underneath the h/light,HTH.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    the kit has 2 balasts and two small bulb checker relays,the lights are brilliant but i think some tiding up of the wires is in order,has anybody managed to put the rubber headlight rear covers back on? if so how?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by bobby-tupper View Post
    Mine went back on. IIRC I drilled a small hole for the wires to pass through
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    If you take the air box out, then you'll notice a gap where you can pass the ballast through and stick it to the inside of the wing, that's where mine is and it fits bob on - its a bit tight, but goes through ok.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    above thats where mine ended up,it took longer deciding where to put the os balast than fitting the lights,
  1. need help fitting sri lip spoiler to vectra
    By dazkaz45 in forum Photoshop section
    Last Post: 18th February 2012, 12:49
  2. Fitting Parrot In vectra Help
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2011, 18:31
  3. Fitting towbar to Vectra C
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 15:17
  4. Fitting a V8 into my Vectra
    By kompkar in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 12:07
  5. Fitting cd changer in vectra c
    By runs4miles in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2008, 11:25
