Results 1 to 10 of 14
Thread: Help with Temp Sender Sensor
    South Yorkshire
    confused Help with Temp Sender Sensor
    Hi, Can anyone tell me where the following items are on the engine. Need to check them as having intermittent revving problems.
    - Temp Sender Sensor Connector
    - Vacuum Pipe
    - Turbo Bost Pipe
    Cheers for help
    Regular Member mattolly86's Avatar
    oxfordshire
    which engine do you have
    South Yorkshire
    Good question, that info would of helped had i put it in description. Its the 1.9CDTi (150) on a 54 plate.
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I told you were your temp sender was is your last thread mate,left hand side of engine on your thermostat housing
    Turbo boost pipe, check all the hoses too and from the turbo
    South Yorkshire
    Sorry to sound thick but what does the thermostat housing look like?. Is it at the front or back of the left hand side of engine. There sems to be plugs all over the shop.
    look between the engine and the battery box...there's an alloy casting on the side of the engine with coolant pipes going to it..on it is a (normally) green centred sender..that is the temp sender
    South Yorkshire
    Cheers GSI, found it. Was looking at Left hand side as told on previous thread. Disconnected it and cleaned it and its now giving me a reading but not going over 85. Possibly due to extreme cold weather at mo.
    CDTi's take FOREVER to get warm...85degrees is low if it's on a run thou...let it sit and run and see if it gets hot enough for the fan to cut in..
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by kryton01 View Post
    Sorry kryton i was only quoting from the haynes manual it says in there left hand side on 19 diesel engines
  1. Un-plugging coolant temp sender plug
    By chaz in forum Engine & Drivetrain
    Last Post: 1st March 2011, 22:12
  2. Where is the coolant temp sensor/sender on a 3.2 Petrol?
    By marcdale in forum Engine & Drivetrain
    Last Post: 1st June 2009, 11:08
  3. Wanted Wiring diagram for External Temp sender
    By flint666 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th April 2009, 22:56
  4. RE-External temp sender fault
    By Charlie miller in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2008, 23:52
