Thread: Jump starting - a query
    Norfolk
    Default Jump starting - a query
    This may be a very stupid question but can anyone please tell me if it is okay when jump starting a car to keep cranking the duff one until it fires i.e. do jump leads get hot over a prolonged period of use and/or can it do any damage to the good battery or the car it is attached to (with the engine of that car running). I am using a good quality set of jump leads.
    My 2.2dti does not want to know on these cold mornings and jump starting is the easiest option, but since it can take up to a couple of minutes to get it to fire up I don't want to create yet another problem trying to solve the first one.
    Thanks for any advice.
    Nicking Ya Dinner.
    You must connect live to live and negative to the jumping car and an earth point on the flat one or you will spike the ecu.
    As far as cranking goes, just rev the jumper to 1500 for a minute or two and then attempt to start the other.
    Belfast
    Really depends on your jumpleads, and what you're jumping it off.
    I tried jumping a totally frozen Laguna 2.2d off a Rover 414. Result? 1 set of melted jumpleads and two dead cars (even with the Rover going at 4000rpm the Laguna killed the battery).
    I got it going after 20 mins of cranking using a beefier set of leads off the tractor (huge battery and 100A alternator)
    Regular Member scottyd's Avatar
    paisley
    or get new glow plugs and a battery
    Norfolk
    Quote Originally Posted by scottyd View Post
    Been there, done that and it still won't go. (Ditto leak off pipes and injector seals!!)
    I'm using wife's vectra 2.2dti for the good battery. At least hers will start in the morning.
    Belfast
    Wanted: Compression tester for 2.2DTi. Must be posted to Nobby's house.
    Norfolk
    Quote Originally Posted by _ZS_ View Post
    But be quick - I could lose patience very soon and feel the urge to get a new car (Vectra of course).
    Belfast
    I can recommend the 1.8VVT. Cheap to buy, cheap to run, more power than your 2.2DTi.
    I'm getting 38mpg out of mine, 50/50 city/brisk motorway.
  1. Replies: 9
    Last Post: 15th January 2013, 14:16
  2. Amp of wires - jump starting
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2012, 00:46
  3. Jump starting
    By SVAC in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 22:45
  4. That made me jump!!
    By ed taylor in forum The 'Off Topic' room
    Last Post: 18th November 2008, 21:42
  5. Cold Starting glow plug query
    By dh.dti in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2008, 12:41
