Results 1 to 3 of 3
Thread: Temperature guage giving silly readings
    N. Ireland
    Default Temperature guage giving silly readings
    Hi all. for a while i have been thinking that my temperature guage is giving funny readings (the outside temp, not the enging temp) and this morning confirmed my thoughts. after de-icing the windows i got into the car to find that it was reading 33oC outside. read through some old posts and found out that the sensor is between the rad and the front bumper so i took it off to get a looks, it looks ok (i.e clean etc) but there is a little bit of corrosion on the contacts. ...then my other half rang me to get a lift homw so i went to get her with the temperature guage still removed. got into the car and expected no temp reading but it was still 33 and as i started to drive it dropped,.......and dropped 33...25.....15...right down to -3.5. so now i`m puzzled. i have removed the temp guage but i am now getting a reading closer to what it should be. is there 2 guages which take a average or is it something else broke) and advice is appreciated
    N. Ireland
    ....bump....
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Fit a new sensor. Even though it looks ok they do go on the fritz sometimes and is a common fault.
    It's the same sensor they were using back on the Cav's and early Astra's and a new sensor always cured the problem.
    Snowman, you got your ears on?
  1. Temperature Guage
    By garetmcc79 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2012, 15:28
  2. temperature guage ?????????
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2011, 09:01
  3. Engine coolant Temperature gauge highest readings you have had?
    By hertscol in forum Engine & Drivetrain
    Last Post: 10th April 2011, 01:03
  4. Inside temperature readings
    By Smove in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2009, 06:27
  5. Outside Temperature Guage
    By Del 2.2SRi in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2007, 20:10
