i did small service on my vectra,had a look around for anything wron,i did not find much except for this,it was loose and could be turned by hand
and it was a pig to do up
oh and the car has full vauxhall service history
did you try a ring key spanner on it rather than a torque
what is that on???...what part?...turbo?
By the looks of the bolt head..someones had a go at that before?? has it had a different gearbox fitted at some stage. Or is the pic taken after you tightend it up.
**** that im going round mine with a fine tooth comb tomorrow
Certainly does look like someone has either slackened it or has had the gearbox off at some point.
Has the car ever had a new clutch or anything major in that area??
There is a very slim possibility it has worked itself loose so i'd keep an eye on it and perhaps put some locking nut glue on it to stop it comming un-done in the future.
Bri
the bolt holding the camchain tensioner to the head on my car just kind of.....well, undid itself and fell out. at 35000 miles, maybe the same quality control guy was on shift when this car went out....
