Results 1 to 10 of 14
Thread: smell from engine
    Feb 2007
    GREENOCK
    Default smell from engine
    when my engine is running fir a while it seems to be a smell when i stop..it smells like anti freeze or somthing like that...there is no leaks as i have been checking now for about 2 weeks...any help
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    This can be quite common when the radiator is starting to go.
    It may not be leaking enough for there to be pools of water on the ground or notice a drop at the header tank but is the radiator wet anywhere?? - check front and back, top to bottom.
    Other than this check all hose pipes that carry your coolant. Heaven forbid there is always a possibility it could be the heater matrix that is leaking or starting to go. Any wetness inside the car?
    Bri.
    Jul 2006
    Just outside the box here - and only because it's hapened to me this week too - just stick your head under the car and make sure there isn't a carrier bag welded to your exhaust.... Smells godawful!
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 7500
    Quote Originally Posted by parapaul View Post
    Yep Paul. My dealer scraped one off the exhaust of my earlier 1.8 as it never got fully burnt off after a month, and I was told it can take up to two months to burn off. Smells like exhaust fumes/burnt fuel (which I suppose it is). If you've ever put a plastic bag on a raging bonfire you'd know what I mean.
    Makes you a bit paranoid TBH. If I see a plastic bag go under my car I check in the rear view mirror to see it emerge out of the back or the other side of the car. Have been known to stop and check if I don't.
    Feb 2007
    GREENOCK
    Default a
    will check this as im not losing any water or have any water inside the car. thanks for the info will try this. its just abit strange, anymore info would be great.
    Regular Member scottyd's Avatar
    paisley
    have you been using your screenwash!!!!!!!!!
    Feb 2007
    GREENOCK
    yes i have. would that sit on the car for a while and smell like this/
    Belfast
    Yeah, it can puddle down inside the wiper assembly area and make a pong.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 7500
    I had smelly screenwash a while back smelt like vinegar and was noticeable from within the car even with the windows closed. I put it down to filling the reservoir with some screenwash I'd mixed up about a year previous which had gone off. Should have known better, I know.
    Feb 2007
    GREENOCK
    Default c
    went out and checked and can see a small bit of smoke coming from the left hand side of the engine..ant help
  1. New car smell
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 31st July 2012, 21:22
  2. Loss of power, engine smoking and strong smell.
    By Catlene in forum Engine & Drivetrain
    Last Post: 4th May 2011, 12:54
  3. You Smell
    By Lump in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2008, 22:10
  4. New car smell!
    By Vectra Singh in forum Detailing and Car Care Discussion
    Last Post: 24th July 2007, 18:41
  5. Blue Smoke from engine and a foul smell
    By Daves Blue SRi Vectra in forum Engine & Drivetrain
    Last Post: 21st April 2006, 21:36
