Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Twitchy front end on 2.2 sri 03
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Twitchy front end on 2.2 sri 03
    help needed the front/steering feels twitchy when driven at speed feels like its squirming all over the road any ideas, tyres are at right pressure, there wearing evenly and no kerbs have been tw4ted?
    Regular Member poves's Avatar
    lancashire
    are your wheel nuts tight ? lol
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    yep all torqued up,unless the wives been at them
    lancashire
    try swapping front for rear but keep em on same side , if u know wat I mean.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    been done already,done know if its a dodgy shocker
    Regular Member old cruiser's Avatar
    slough
    Is it that your steering feels quite light as they all seem to and is responding to any oddities in the road, if you see what I mean.
    Cheers Pete
    lancashire
    to be honest , I had the vec b sri , and it was like a gokart , would'nt dare take roundabouts , corners at the same pace in the c , It may be suspension , get it checked out buddy , but be sure to get a few opinions.
    slough
    If all suspension components are ok ,it might also be worth getting a proper 4-wheel alignment done as it's also possible that it's the rear end causing the problem as was the case on my old facelift Omega which now as I remember had a similar feeling , as it turned out the thrust angle was miles out which needs to be set before any adjustment of the toe is done on the front, as it seems alot of places claiming to do wheel alignment just seem to ignore the thrust angle and what it means and therefore what are they setting the front toe against!! and I have actually asked some of these places this question before now and it's been a case of 'What do you mean Sir' !! that just about says it all!!
    Cheers Pete
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    it feels like im driving on ice if that makes sense
    slough
    Could well be a geometry issue in that case as that's how my omega felt before it was 4- wheel aligned properly, in fact if I remember I used to thnk to myself 'might as well let go of the steering wheel and let the car do it's own thing, coz it's obviously what it wants to do' !!
    Cheers Pete
  1. twitchy rear end
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2013, 17:51
  2. Really twitchy around corners
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2011, 22:33
  3. Vec C twitchy Front end
    By Grovercus1969 in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2010, 20:10
  4. Twitchy Rear End
    By Mini the Minx in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2010, 04:02
  5. twitchy signum
    By Martybhoy in forum Handling & Braking
    Last Post: 18th February 2009, 21:32
vectra c front end feels twitchy
