Thread: help needed on removing back door glass please guys!!
    DURHAM
    Default help needed on removing back door glass please guys!!
    Anyone no how to take the door glass out on a vectra c or have any info or pictures out of a haynes maual.
    Try the how2 on installing rear electric windows mate...
    Regular Member poves's Avatar
    lancashire
    from wat I remember the glass is on a plastic clip that locks , like a tab in the middle of the glass . But I think it's a tight fit in the frame , u will need to remove the torx bolts from the bar on the plastic triangle insert and move or remove , u will see wat I mean. good luck.
    DURHAM
    I have removed all the bolts and taking the slide rod out but its the white plastic clip what holds the glass in i am stuck on now, i dont no how to open that type clip its driving me mad.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    look in the how to for fitting rear windows.. theres a little clip that holds the windowglass.. and remenber to buy newones.. about 25 pennies a piece.. i broke mine when taking them out.
    lancashire
    does the centre of the clip push through ?
    If not just ease the tabs apart on the clip , but be careful not to blow the glass.
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Does NOT push through.. either take apart gentle.. (or like me a large screwdriver and just break the clip)
  1. Advice needed on removing door panels....
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2012, 12:45
  2. Removing light scratches from glass
    By Steveocee in forum Detailing and Car Care Discussion
    Last Post: 10th September 2011, 07:34
  3. door mirrors - removing the back covers?
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 21st February 2011, 23:30
  4. Removing Wing Mirror Glass
    By Das in forum Bodywork & Interior
    Last Post: 29th July 2010, 10:50
  5. Removing Door Mirror Glass...
    By Dan_BlackSRi in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2009, 10:29
remove door glass vectra c
vectra c rear glass removal
how to fit rear door glass on a vectra c
how to fit vectra c rear glass retaining clip
replace rear door glass vectra c
vauxhall insignia rear door window removal
vauxhall insignia how to replace rear window glass
insignia estate how to remove rear windows
insignia rear glass removal
vectra c back doors remove
how to replace rear door glass in vectra
vauxhall insignia door glass removal
vauxhall insignia 2012 rear window glass removal
vectra back glass removal
remove window from vauxhall backdoor
vectra rear glass reoval
remove vectra rear door glass
insignia rear door glass removal
vectra c replace rear door glass
2009 vauxhall insignia rear door window removal
