Thread: Cold running on 1.8 vvt
    Hull
    Default Cold running on 1.8 vvt
    Hi i have a 56 plate Vectra 1.8 (vvt engine) it's got 29,000 miles on the clock and when i start from cold under any kind of slow-mid accelaration it seems to stutter and struggle. It only does this from cold and it's showing up no lights. I take it this is going to be a garage job to get codes read, but wanted to check to see if theres anything i should look at first??
    Belfast
    If there's no light, there's no codes.
    How long does it take to clear the stuttering?
    Regular Member petel's Avatar
    Nov 2007
    bristol
    mine is like that but only for a few minutes and when its stone cold.You can feel it being a bit reluctant to rev,mostly in third around 2000 rpm.After a couple of minutes it feels fine.Its like the engine is saying 'bog of i,m cold' !
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    tried a new set of plugs mate? when was it last serviced ? ( oil/filters/plugs)
    Hull
    TO answer questions car was last serviced about 8,000 miles ago (i presume it says so in the book) IT takes the car about 2 minutes to stop doing this and about 10 minutes for the needle to move from the bottom of the guage on engine temperature.
    Thinking of going down the route of changine the plugs and leads if need be wasnt sure if it was worth getting a stealer to look at it. Possibly warranty? but if it's plugs it'd just be wear and tear surely?
  1. Quick one.. Running cold
    By goafer in forum Engine & Drivetrain
    Last Post: 6th December 2010, 07:09
  2. Running Cold
    By dc6839 in forum Bodywork & Interior
    Last Post: 29th November 2010, 18:43
  3. Running too cold
    By crgv6 in forum Engine & Drivetrain
    Last Post: 25th February 2010, 20:18
  4. 1.8 petro/lpg running cold
    By Tecnobaz in forum Vectra C / Signum Troubleshooting
    Last Post: 26th December 2009, 20:31
  5. 3.2 V6 Gsi Rough Running From Cold
    By TOON VECTRA V6 in forum Engine & Drivetrain
    Last Post: 13th December 2006, 22:20
