Thread: couldnt get door card off...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Arrow couldnt get door card off...
    Hi guys
    i was planing to get my drivers door card off..
    i followd this thread.. http://www.vectra-c.com/forum/showthread.php?t=39368
    but even that i used violens.. i couldnt get the top to release... is it just to use even more force? (used that much that the bit below the mirror cracked...)
    Ken
    Regular Member Whippy's Avatar
    Oct 2007
    wirral
    i didn't remove the rubber.
    i pulled the doorcard off the rubber from the 4 or 5 metal clips that hold it on.
    1 or 2 stayed on the doorcard but they pop out with a screwdriver/pliers and push back on the door rubber.
    that was on a facelift though.
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    i didnt have problems with the rear doors.. so i expect that the front was the same.. with the clips in the top.. but i actually gave up not wanted to destroy them more..
    it was the metal clips i couldnt get to release...
    cambs
    hi
    unscrew all screws and pull the door card out as far as possible.
    then get a flat screw driver and prise the top clips off from inside.
    a bit fiddly but it worked for me.
    Once you've got the bottom part of the card off and away from the door and just the metal clips on the top part still attached, get something like a small hammer and put the end of the handle inside up against the top of the door card at a few different points and give it a few whacks with your end - that normally releases it.
    Sunny Dartmoor
    I found if you lower the window and remove the doorcard from the door by reaching through the open window is the easier way of doing it,good luck ken......
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    thanks ill try the different things... to se what works..
    its because im trying to find out if ihave the correct wires for folding and dimming wing mirror .. now i managende to get the "speaker" at the wing mirror off for pictures of that..
  1. Behind The Door Card
    By Tam80 in forum Bodywork & Interior
    Last Post: 21st April 2011, 22:02
  2. i need a door card but fixed my door
    Last Post: 11th March 2010, 11:52
  3. door card help
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 19:37
  4. door card
    Last Post: 28th April 2009, 19:00
  5. Door Card Help
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 17:19
