Headlight bulb has just gone and flashed the low beam warning on the display, i've put a new headlight bulb in but but that still doesn't work.
I've found this thread but there is still no answer, does anyone have any ideas??
Pricey.
Pricey.
try fuses or just switching them off and back on again if you changed the bulb with the power on
Problem solved I hope.
Disconnected the battery for 30 secs and it seems ok again, fingers crossed.![]()
There was a fault on some AFLs
the little plug were the bulb plugs in (D1S) It can fall out or just come a-bit loosegiving the dip beam out warning due to high heat
had mine into the dealers for this only the other week
the fix is high temp tie-wrapsto keep the plug on
i noticed mine was flashing but only when i went around corners, straight ahead it was fine until it just stop working around a corner
hope you didn't bin your old bulb as it could have been OK
from what I've found out AFL'S go PINKwhen they are about to go
It's ok Thunder, it was me posting from Paul's computer. His AFL's are fine for the time being.
It must just have been a glitch with the bulb check system as the old bulb works fine aswell now.![]()
lol split personality![]()
Glad you've got it all fix & working![]()
