Thread: Full steering alignment check
    Regular Member jamesr's Avatar
    Lancashire
    Default Full steering alignment check
    Just had my car checked on the Hunter Equipment as recommended by users on this forum.
    Car was checked after fitting lowered suspension - really pleased with the results and the handling has improved loads.
    Here is the before and after print you get for your £80!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep good to get it done correctly. Always get mine checked every 6 months, no charge if no adjustment needed
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    James - how long did it take?
    I too tried to get a localish place with Hunter Equipment to do the same (Loudwater Tyres as on the alignmycar.co.uk website) and was quoted £35.
    You'll see here why I didn't go ahead with it http://www.vectra-c.com/forum/showthread.php?t=63133
    Going to try another garage with the Hunter Equipment - the gear is only as good as the muppets using it.
    Lancashire
    Quote Originally Posted by gtr1000 View Post
    Took about an hour - the service was excellent.
    They even put 70kg of weight in the drivers seat to make it as accurate as possible(never seen that before)
    Yes it was £42 plus a charge per adjustment!
    Don't mind paying for a job well done.
    For all you guys up north - www.nigellangsgarage.co.uk
    Surrey
    Quote Originally Posted by jamesr View Post
    Only 70 kilos
  1. Steering wheel off centre after alignment
    By pipamish in forum Engine & Drivetrain
    Last Post: 1st June 2012, 15:58
  2. Pulling to the left - after full alignment!
    By watchman in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2010, 08:10
  3. Vectra c steering wheel alignment
    By stumpinuts33 in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2010, 14:42
  4. Full MOT history check.... FREE...
    By Miketwinny in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2009, 15:00
  5. mis-alignment of steering cowel
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2008, 18:21
