Thread: programing a new door stay assembly
    Regular Member neil0748's Avatar
    Jan 2008
    Bridgend s-wales
    confused programing a new door stay assembly
    if you buy a new door stay assembly does it have to be programed into the onboard computer because iv'e got to get a new one main dealer tells me it might have to be programed is it true or not thanks.
    Door stay assembly? Are you meaning a new door module? If so then yes the usually need programmed in when fitted.
    Jan 2008
    Bridgend s-wales
    thanks duncan what i meant was a new door module because the dash is telling me that the door is open when it is not, cheers mate for that info looks like i will have to have the main dealer to fix it then.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Quote Originally Posted by neil0748 View Post
    could be your door lock if it is showing door open ....try giveing the door a good slam it may fix the problem ...
    Ah gotcha. As benny said it could be the lock assembly needing cleaned/replaced, although the first thing to check would be the striker plate. it may need moved in/out to make the switch make full contact.
    Jan 2008
    Bridgend s-wales
    confused door lock
    hi thanks for the reply ive striped down the door lock and adjusted the striker plate still didnt work. yesterday the ****** central locking worked
    swap the lock out before the door module....99% are fixed with just the doorlock..
    Jan 2008
    Bridgend s-wales
    i will hang on for a while to see if it goes again iv'e bought a new lock for it just incase it goes again £46+vat from main dealer f.r.f in bridgend s.wales it took 2 weeks to come from germany they dont stock it any more they told me thanks gsi
    Jan 2008
    Bridgend s-wales
    change the door lock it was faulty i had to drill out two pop rivits that held the guide for the window dont take it out just turned it to the left out of the way so that i could get to the lock. i then turned the lock on its side to the left so that i could disconect the last link rod going to the key lock very very fiddley. Reasembled and checked before putting the door panel back happy chappy now and every thing is working fine thank god thanks boys
  1. Clunking door stay.
    By mark1319 in forum Bodywork & Interior
    Last Post: 19th April 2014, 13:46
  2. How2 fix clunking door stay
    By luke4487 in forum Bodywork & Interior
    Last Post: 29th January 2013, 19:53
  3. For Sale: Vectra-C/Signum Driver Complete Door Mirror Assembly - ULTRA BLUE
    Last Post: 10th October 2012, 16:19
