Thread: High Pressure Fuel Pump Replacement V6
    Hampshire
    Question High Pressure Fuel Pump Replacement V6
    I've just had mine done under warranty Diesel Dog has told me its a common problem with facelift vectras (see link)
    http://www.vectra-c.com/forum/showthread.php?t=60855.
    I've browsed this forum and most issues appear to be after remapping the engine.
    Has any one else had to have their high pressure fuel pump replaced pre or post warranty and was the engine remapped or not?
    Only one that I know of, Mavericks old signum had it replaced. It went tits up right after a remap.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI160
    Year : 2012
    Yep, definitely user name "Maverick"'s one went - and it was remapped I think I read.
    There are quite a few others I remember, also check posts by "VectraV6CDTI" & "willc01" - that one was an absolute nightmare if I remember correctly!
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Had a 'fuel suction kit' replaced on mine but not sure if that includes the pump or not I've asked for a print out of all warranty work done so when I get that I'll hopefully be able to post up and clarify.
    I've mentioned it before, if you have a 3.0 V6 CDTI then it is best not to perform any type of engine enhancement
    A remap might cost you £200, save you £500 in fuel, but eventually the fuel pump will fail prematurely and cost you vastly more than what you have saved, as well as you probably having to remap back to default
    Hampshire
    Does anyone know if the replacement pumps have been modified to reduce the failure rate or are they still fitting the same type regardless?
  1. High Pressure Fuel Pump
    By trevteah in forum Engine & Drivetrain
    Last Post: 9th October 2010, 19:09
  2. Z22YH High Pressure Fuel Pump
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2009, 23:01
  3. air con and high pressure fuel pump
    By dayna1501 in forum Introduce yourself.
    Last Post: 23rd June 2009, 18:52
  4. High pressure fuel pump
    By dougiemc in forum Engine & Drivetrain
    Last Post: 3rd May 2009, 21:32
  5. High Pressure Fuel Pump
    By nesbigr0 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 17:08
vauxhall diesel high pressure fuel pump
https:www.vectra-c.comforumshowthread.php63356-High-Pressure-Fuel-Pump-Replacement-V6
