what would the benefits be if i would lower my elite 35mm and adjust the camber
cheers dan
cheers dan
the lower center of gravity helps on cornering and less roll
would there be any point with the camber adjustment or would it just be a waste of money
you really need it done but a lot of people dont bother.
cause i noticed on lmf you can buy the camber adjustment bolts for the front would they be the ideal thing
they are made to make it easyer to adjust the camber.but i dont think you need it as it just makes it easyer to adjust.
for how much they are i would buy them anyway m8 allways better to have all the correct parts.
i didnt have mine adjusted and its wore the inner side of my front tyres out so its worth getting checked once the suspension has settled.
i thought it would eb better to buy the proper kit cause im not that up on my knowledge of suspension
you might also need some bump stops aswell m8.
not to sure but some-one will probely tell you if you need them.
