Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Draft near the gear stick???
    Regular Member Big Davie's Avatar
    Jan 2006
    having a giggle...
    Default Draft near the gear stick???
    Just a quick one to see if anyone has noticed that they are getting a draft near the gear stick area, I have given the site a wee look for this prob and cant find that anyone has covered it. Or is it just me. The draft in question only seems to happen at certain times and for a short period, can anyone help?????
    Regular Member MLC's Avatar
    uk
    Is the missus eating to many beans.
    Have you seen if it 'drafts' when the rear air vents are open or closed??
    Never heard of it but the ducting for the vents runs up the tunnel i believe..Could have a split in it.. Duncan is your man for what's under there..
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    @MLC
    Dec 2005
    I have this same thing on mine, never have sussed exactly where it's coming from.
    Jan 2006
    having a giggle...
    Alright, to stop the jokes whafting in I should have worded the thread a wee bit better. The draft is a cold one, so thats the other half off the list.
    (I'LL GO AND GET THE SHOVEL)
    do you think it's air from outside the car??
    Dec 2005
    Quote Originally Posted by Gsi3.2
    Deffo in mine, dolder it is outside the colder the draft. If you tend to drive with one hand on the kn...lever like me, your fingers freeze in current weather.
    Rotherham
    I get this aswell, i have also figured out that its only when i'm turning a corner, i just put it down to the power stearing pump stealing power from the heaters or something along those lines. I know thats probably stupidly wrong, but tbh it hasn't bothered me enough to spend more than half a second thinking, ooh it got cold then.
    Jan 2006
    having a giggle...
    Yes this is a definite as I have tried to solve this problem going out with all the vents closed (and minus the wife?) and its still there.
  1. gear stick
    By caitlin6 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 20:54
  2. gear stick
    By SarahP in forum Vectra C / Signum Troubleshooting
    Last Post: 13th July 2012, 09:58
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
