Thread: Light scratches
    Chester
    Default Light scratches
    Anyone know the best thing to use to remove/hide light scratches on a star silver sri??
    Regular Member Lump's Avatar
    coventry
    yes mate this is as good as it gets
    Northampton, UK
    I got swiped by fallen tree branches down a country lane the other day, just used a bit of T-Cut Paint Restorer and then polished off. Scratches gone!
    Chester
    Thanks for the tip. Will give it a go on Sunday.
    Regular Member Little John's Avatar
    North West
    No don't use tcut its shocking stuff. It is too agrassive and use it to long you can remove all your paint.
    Get somthing like megs scratch x or someone with a machine polisher to sort it out for you.
    coventry
    i was reading a thread on DW and they used 3 coats of Auto Glym super resin polish. and it really reduced the appearance of fine scratches
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Currently- VW Golf
    Trim : Mk7 R 300bhp
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Thumbs up
    Don't be afraid to 'blend' 2 polishes together.
    A light cut and a ultra light cut polish work well, i've done this a couple of times when i've got low on my favourite brand and the results are excellent.
    coventry
    yes i do that alot at work, ive got a mix i use 90% of the time
    0.5 machine glaze
    0.25 med cut paste
    0.25 high gloss polish
    really good for hand polishing. if you find some thing need a bit more work just spend a bit more time on it
    Midlands
    AG SRP won't remove the scratches, it will simply fill them in. It's a filler heavy product thats used by people who don't have rotary or orbitals. People with machines should only ever use it if the clearcoat is to thin to work with. After repeated washing/driving in wet conditions they will become visible again using the SRP.
    Your best bet would be to find someone who can machine polish. They will start out light upping the cut each time so the minimum amount of clearcoat is removed. If the scratches are bad wet sanding will need to be used followed by a machine polish.
    The cheapest and safest way would be to take it to your nearest chipsaway dealer - simply ring up and give them your postcode to find out. Excellent service at my local one.
    North West
    I wouldn't be so sure about chips away being the cheapest, I got one round to have a look at some key marks (before I was polishing myself) and the quote was £5 more than the local highly recomended bodyshop who was going to take the area back fully, primer paint and clear the bits that needed doing and blend. The guy even did a few extra bits that I didnt ask to be done.
    So check bodyshop prices out as well.
  1. full of light scratches
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2012, 21:20
  2. Light scratches on windows
    By Ralphwells1967 in forum Detailing and Car Care Discussion
    Last Post: 10th December 2011, 23:54
  3. Removing light scratches from glass
    By Steveocee in forum Detailing and Car Care Discussion
    Last Post: 10th September 2011, 07:34
  4. Getting light scratches out of paint work?!!
    By Mads in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2008, 18:31
  5. Scratches
    By Matt21385 in forum Detailing and Car Care Discussion
    Last Post: 8th June 2006, 16:57
