Thread: bit of help needed if poss!!!!!
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    Default bit of help needed if poss!!!!!
    as above i have bought a ipod kit from dice electronics .i need to wire up using a ground ,ignition and 12 v supply 3 in total .anybody know which wires on the back of a cd70 navi i can splice into
    cheers jon
    Oct 2007
    Shropshire
    Go to the cigarette lighter socket. The wire going to the centre of the socket is your switched ignition +12v. Ground and perminant 12v can be got from the back of the radio (the pins are labelled on the radio) or if your unsure you could go straight to the battery.
    Regular Member mattolly86's Avatar
    oxfordshire
    id splice off your stereo connection red black and yellow
    red perm live
    black ground
    yellow ignition live
    (may have got red a yellow wrong way round i think its opposite on vx)
    Regular Member Robclowes's Avatar
    Oct 2007
    Crewe/Market Drayton
    did this work???
    Oct 2007
    Shropshire
    If its full canbus then there is no switched +ve behind he radio, thats why I said go to the cigarette lighter socket, it would work whatever model/year he has
    May 2007
    manchester
    thanks for the help guys not done it yet will have a go tomorrow think i may just go to the battery save hacking into wires and the use ciggy lighter as said
  1. bit advice needed if poss guys
    By callum in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd September 2012, 12:26
  2. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  3. Semi-Legal Advice Needed Quickly If Poss!
    By aaruck in forum General Chat
    Last Post: 9th July 2008, 21:15
  4. I Need a Fix If poss
    By The-Bandit in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2007, 00:16
