Thread: Rattle from clutch when pedal is pressed half way down.
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default Rattle from clutch when pedal is pressed half way down.
    Over the last week i've noticed the gear box seemed to be a little bit notchy (it's the best way i can think to describe it) when selecting 1st or 2nd gear first thing in the morning and just put it down to the change in climate.
    When i finished my night shift this morning i started the car up and went to drive off then i noticed a rattle coming from the left hand side of the engine bay when the clutch pedal is pressed half way to the floor.
    Anyway my car was booked in at my local dealers for this morning to have the handbrake recall done and was told it's a 15 minute job i then explained the noise when the clutch is pressed and the bother with the lumpy gear box.They said they'd have a look anyway, I've just phoned the garage to see if the cars ready and was told "they're still working on it."
    Has anyone got any ideas what it could be the cars a 55 plate facelift sri cdti (150) with 41000 miles on the clock. Surely if it's the clutch i'd be covered with the 3 years manufacturers warranty as the car isn't 3 until January '09.
    I'm waiting on the garage phoneing me when the cars ready i'll let you's know how i get on.
    Regular Member Ralph wiggum's Avatar
    Oct 2006
    Bexleyheath, Kent
    3 Words I'm afraid mate "Dual Mass Flywheel"
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    A mate of mines Vectra has been doing it for ages mate (too expensive for him to fix) - its the DMF and is not a cheap job to fix (although you should be ok with your warranty).
    S.Lanarkshire
    Its the Fly Wheel and clutch both will be replaced under warranty on tuesday.
    S.Lanarkshire
    Didn't get the car back until wednesday as they had to take it away to get the 4 wheels re-aligned. Apparently they have to drop the sub frame to get the gear box out , which means disconnecting the steering at the front end.So they realigned the 4 wheels free of charge.
    Anyway mechanic told me that the clutch kit is about £300 and the fly wheel is about £200 and i'd probably be about £400 in labour costs as well if it wasn't under warranty.
    The same mechanic then told me that "the flywheel used to be solid (in 1 piece) and vauxhall changed the design and it's now in 2 bits joined together as it absorbs the torque from the engine better giving a better pick away". I then asked if Vauxhall have changed the design of the flywheel or have they just fitted the same flywheel back onto my car which has just packed in after 41000 miles. He replied "They haven't changed the design of it".
    Regular Member cheekylemon's Avatar
    Aug 2007
    Droitwich - Worcestershire
    Ahh crap my 04 sri is doing this. What happens if I ignore the rattle when the peddal is pushed halfway down? Will it cause a nuclear explosion ??
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Mines is also doing this cant aford to do anything with it at the moment will it be ok for the short term oh my cars just touched 56k what surley a flywheel should last longer than that!
    Aug 2007
    Mines done 125k so cant complain i guess
    N.Wales
    ah ****** heck... mine has a similar sounding problem... only done 41k though! thats shocking!
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Rattle, Knock & Dodgy Clutch Pedal - CDTI 120 - HELP!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th September 2010, 19:15
  3. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  4. noise when clutch is pressed???
    By thompo5 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2008, 17:58
  5. DMF, Who's got the rattle when the clutch is lightly pressed ??
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 03:24
clutch noise pedal half way
Rattle on clutch pedal about halfway
Vectra rattle when half clutch
clutch noise half way
volvo clutch rattle when half way depressed
half pressed clutch noise
opel astra clutch noisy when Halfway
vectra rattling noise when clutch depressed
rattle half way down the peddle of car clutch
clutch rattles when pressed halfway
clutch rattle pedal half depressed
vectra cdti clutch noise when halfway
noise when clutch depressed halfway
vauxhall insignia ratlle throw peddle
clutch noise half pedal
Vauxhall vectra 2002 rattle when clutch depressed
opel insignia noise when pushing clutch
