Thread: HHHEEELLLPPP!!! 1.9CDTi broken
    South Yorkshire
    Angry HHHEEELLLPPP!!! 1.9CDTi broken
    Hi all. Ive had my DMF changed (3 years ago), EGR Valve changed (2 years ago) and my Swirl Valve and Inlet Manifold changed (2 months ago). Now my cars bellowing smoke out and the throttle will only increase the revs very slowly.
    The engine starts fine (although very smokey) but just wont do anything. There is no warning light on the dash.
    Been to speak to my local garage (non-dealer as car is undrivable) and he thinks it might be the EGR Valve stuck open (can I check this myself). The car had not been run for over a week prior to it displaying this fault but it did drive ok for a mile or so but wouldnt play when I restarted it.
    Any suggestions guys. Is there anything I can check myself. This things doing my head in.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Apparently mate you can clean the EGR your self but i would not know how to do this my self
    South Yorkshire
    Fiddled with injectors and tapped EGR valve with a hammer and it does run better but still shed loads of smoke.
    Any tips?
    The search button is a useful tool
    Here you go LINKY
    East Midlands
    Quote Originally Posted by kryton01 View Post
    If it was the EGR valve i would imagine your car to be showing a fault code..ie dash light with spanner through it.i could be wrong i suppose.
    South Yorkshire
    Is the constant light blu smoke an issue? Would the EGR cause this? I have had a look on ebay and found a new egr valve unit for £45
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    Are you sure it is blue smoke??
    Black smoke is okay - usually lack of air / too much fuel (MAF Sensor)
    Blue smoke is bad - usually means burning oil (Expensive)
    White smoke - can be good or bad usually normal.
    I would certainly be visiting a trusted mechanic for advice if i was you. Sometimes DIY is okay and cheapest option but in the case of Blue smoke i'd let a mechanic tell you even if just to tell you whats wrong then revert to the DIY if confident enough to do job required.
    Bri.
    South Yorkshire
    Managed to take her for a run this morning (after fiddling with injectors and finding a loose pipe). Couldnt decide what colour smoke was so gave it a blast which resulted in a cloud of black smoke, after which it stopped smoking altogether.
    Still a little hesitant until turbo kicks in but then it flies, smoke free.
    Ive posted a new thread to fully explain.
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. 2 Broken Rear Springs VECTRA SRI 1.9CDTI 2006
    By mani911gt3 in forum Suspension, Wheels & Brakes
    Last Post: 8th August 2012, 09:53
  3. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  4. 1.9CDTi Broken Timing Belt at 69k Miles!!!
    By Vectra-sceptic in forum Engine & Drivetrain
    Last Post: 24th September 2010, 15:16
  5. broken front spring on signum 1.9cdti
    By dcdevlin in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2009, 03:53
