Thread: dash board cut out
    Regular Member dax's Avatar
    Anglesey
    Default dash board cut out
    I have an 03 veccy club,this morning i started the engine and all the dash cut out,all the dials,indicators,steering wheel controls for the radio, and the wiper controls,on re-starting the engine they worked fine for 5 mins then it happened again and all stayed dead until i re-started,now the car has warmed up its fine no probs, had car sin Jan and been fine since today, any ideas????????????
    Surrey
    Is there a sensor loop wire around the steering lock?
    Anglesey
    ok thanks will check it out
    Cim connection issues?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Or ABS plug.
    Regular Member garvey's Avatar
    Co Durham
    sounds like abs plug I used to have the same problem
    norfolk
    Default dashboard falts
    hi dax same probs with mine have you found a cure yet
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by johnrolfe View Post
    I did, just gave the ABS plug a squirt with WD40. There are other causes for the failure, but I struck lucky and got the Cheep option. The other one is a new CIM at about £350-£400 dealer fix.
  1. dash board camera
    By skidmark1 in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2012, 19:30
  2. Help with dash board lamps
    By jacko52 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2010, 18:03
  3. dash board.
    By delboy2028 in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2010, 20:22
  4. dash board bulbs
    By andrew m in forum Styling
    Last Post: 15th May 2009, 10:01
  5. Dash board removal?
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2007, 22:10
vectra c dash cuts out
