Results 1 to 10 of 22
Thread: 1.9tdci won't rev
    Malton
    Default 1.9tdci won't rev
    Hi guys, new here looking for help with my car
    Jumped in it to get to work today and it won't rev. Even if I floor the throttle pedal the revs slowly creep up to about 2000 rpm and won't get any higher. It runs smooth, but won't rev.
    Any ideas?
    Thanks Graham
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    mate
    Is the spanner light showing on your Dash??
    Malton
    Hi, and thanks.
    No, no spanner light
    G
    South Yorkshire
    Are you getting any smoke from exhaust?
    Apr 2008
    Liverpool
    I have had a problem on my CDTI the spanner would come on and then would not rev.
    It could be a number of things but im not sure as I got rid of mine a day later.
    Does this happen every time you start it?
    Some one will be on here shortly with some more info
    Malton
    I don't think that it smokes.
    I just went out and tried it again and it's now fine Well atleast I'll be able to drive it to the garage. Oh joy, an intermitant fault
    G
    Malton
    Well the garage have rung, no fault codes, it has latest firmware
    I need to take it when it's doing it - oh joy.
    G
    Oct 2007
    Gloucester
    Sounds like exactly the same problem that my Veccy is suffering from.
    A couple of days ago, I noticed that the car wouldn't rev and had no power below about 2000rpm. All of a sudden, the turbo would wind up and then whoosh! - off I'd go. I've had in the shop today and they changed the mass air flow meter which seems to have made things better. It hasn't solved the problem. It is still reluctant to pick up below about 2000rpm but at least it'll get the car moving.
    I still feel that it's likely to be a coked up EGR valve. Maybe yours is the same.
    Oh, and mine didn't show up a fault code either.
    Regular Member s0501291's Avatar
    Warrington
    Just a guess but it could be the throttle position potentiometer, that is the bit of kit thats connected to the accelerator pedal. As you may or may not know the throttle on the vectra C isnt a cable linkage, its electronically controlled. But as mentioned above it could be a number of things, but good suspect!
    Pete
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Are you all low mileage drivers? As the EGR tends to get clogged up when there is not much motorway mileage done. Split turbo boost pipe perhaps, not sure if this would throw up a fault code or not. Just guesses but I reckon someone will be along soon with some better ones.
  1. 1.9TDCI 150 timing belt
    By Cymrogwyllt in forum Engine & Drivetrain
    Last Post: 21st January 2008, 21:14
