Thread: Outside Temperature Sensor
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    Default Outside Temperature Sensor
    I have replaced my outside temprature sensor as it was giving me some crazy readings (-35 degrees)
    Since replacing it, it now reads correctly after settling down after a period of driving but still displays crazy readings when the car has been sat up for a period of time (say overnight)
    Any ideas why or how to calibrate?
    cambs
    hi
    just an idea but try reconnecting it and disconnecting the battery for a 20mins.
    make sure you have the code for the radio.
    Devon
    Engine : 2.0 Turbo
    thanks tried that, still the same
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 103000
    The new sensor could be faulty too
    Regular Member videodoctor's Avatar
    Blackpool
    Have you checked the connector where it fits onto the sensor.It might be dirty inside it causing a bad connection.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Have you connected the positive to the negative, cleaned the connections, removed and debris that may be there or around them? Does it need tech2 in like hu?
  1. Outside temperature sensor gone mad!
    By devore in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2013, 16:58
  2. Outside Temperature Sensor
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2009, 23:35
  3. Outside air temperature sensor
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 13:31
  4. outside temperature sensor
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 17:23
  5. Outside Temperature Sensor U/s
    By turnerk in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 22:05
vectra outside temperature
