Thread: problems only when towing
    Apr 2008
    CO DURHAM
    Default problems only when towing
    i have a 2.2 dti and when i tow hard for hills and overtaking the limp mode kicks in dont even have to stop just switch the ignition off straight back on and its ok back to normal any ideas anybody also i dont know if its connected but if i am on cruise control as soon as i put my foot on throtle the limp mode again comes on again only when towing .then after all this the cruise wont work for between 10 mins and 1 hour then its fine ..this is only when towing never misses a beat when car is not towing ...any body any ideas as this is getting me to think that the car needs selling as i have lost all heart in her .....
    There's a good chance it's due to this. Give the hose a really good inspection for any splits - which could be quite small and not noticeable.
    Apr 2008
    CO DURHAM
    tried that duncan all is fine its getting to the point of getting rid of the veccy as its doing my head in
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Yeah i have had the same problem m8. (Not towing just in 5th gear over taking) I inspected the boost hoses - no splits. So i cleaned the boost sensor which made it ok for a bit (few weeks) then it came back so i decided to remove the egr valve and remove the top off the inlet section the boost sensor plugs into. Both were jammed with carbon so even though the boost sensor was clean the area it was reading wasnt if you catch me. Anyways after a good clean out and refit (really easy job) (there is a how2 for the egr valve the other part is just 4 screws) its working fine no more limp home and boosts much better. Defo worth a shot. If you need any info on any of it let me know.
    HTH Steve
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    Buggy 66 if your still having problems check your vacuum actuators you 3 on a dti 2 on your bulkhead above your radiator and one by your maf sensor , also check your hoses are connected up correctly to them . i went through all the faults highlighted on this and the other thread and mine in the end was tied down to one of the actuators going faulty and the hoses connected up in reverse on the two actuators on the front
    and still loving it
    Apr 2008
    CO DURHAM
    just took egr valve off and what a shock the egr was not too bad but the inlet manifold was gunked up to hell with carbon and the boost valve housing was bad too .just took it for a run and all seems fine a bit more responsive .but the trouble is only when towing so will have to see when i tow again .will check the vacuum actuators and see if i can find the piping diagram to make sure the pipes are on right ...will keep you informed
    Nov 2007
    yep there is some crap gets in there, as long as its playing better now... let us know how the towing goes.
    Trim : /Elite
    Mileage : 34900
    buggy have a look in the car chat section of the forum and search for a thread called (problem is back again ) .in here you will find a series of photo,s showing which way your vacuum tubes should be ,plus other info
    and still loving it
    Apr 2008
    CO DURHAM
    am i doing this wrong or what cant find post over 500 pages
  1. Towing help
    By marc vectra sri in forum General Chat
    Last Post: 26th April 2012, 16:21
  2. towing
    By jsnlvxr in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 14:01
  3. Towing?
    By Si Jonz in forum Suspension, Wheels & Brakes
    Last Post: 19th October 2009, 12:51
  4. towing a car
    By steve.s in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2007, 18:39
  5. Towing Eye
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 08:49
