Thread: air conditioning fan??
    Regular Member alexander08's Avatar
    derry
    Default air conditioning fan??
    right i went to see a vectra .. seems awright apart from the fan only works on number 4.. why is this? and is it easy fixed? thanks in advance..
    derry
    aw aye and forgot to mention.. not really a mechanical person.. so would have to get a mechanic to do the work so what you think it would cost to get it fixed.. thanks..
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    im not to sure on that one mate My girlfriends 07 Corsa had a problem were the heaters were intermitant and needed the blower replaced not sure if its the same problem thou
    derry
    thanks for the input sean.. aww i hate problems like this.. just read somewhere there that they had similar problem and it was a resister pack or something it was caused by the pollen filter being damp or something and some gutter blocking up?? lol things like this go over my head.. anyone ever had this problem or know how much it would be for a mechanic to fix it ?? thanks again..
    Yep, it's more than likely the resistor pack often caused by it getting wet with water ingress - the blocked up drain holes being the usual culprit.
    Have a search for resistor pack and you'll find a few threads.
  1. Air Conditioning
    By scarydeath in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2012, 20:32
  2. air conditioning
    By andyd in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 11:39
  3. Air conditioning HELP!!!!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 1st June 2009, 11:44
  4. Air conditioning
    By cbee101 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 14:44
  5. Air conditioning
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 21:32
