Thread: HELP: Problems with idling URGENT
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default HELP: Problems with idling URGENT
    Well just been for a meeting with my boss to confirm my redundancy. Get home after a 200 mile round trip and............
    Come up to traffic lights and stop. Idle goes all lumpy and the car and spanner light comes on.
    Drive away and no problems. come to stop and idle again and car will be fine for a short while then starts being lumpy again bringing up the car and spanner light again. Pull away all seems fine, only seems to occur when at idle.
    Had a similiar problem a while back but as well the lumpy idle the car would struggle to pull away. Found the problem to be a plug fitted to the thermostat was not fitted correctly by VX when they fitted my new engine (also found 3 other plugs not fitted correctly!).
    So anyways go to use the U480 scanner I got the other week and it tells me no codes are stored so that was a waste of money.
    So guys any ideas or suggestions before I head off to the stealers?
    Mileage : 000
    I wonder if it is the air control valve or the air flow meter. I would try cleaning the air control valve first ( I use carb cleaner on the wifes vectra B).
    PS I take it your motor is petrol?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Hi Ed, its a diesel 1.9 cdti 150 2005 sri
    Have had the EGR Valve apart to find very little crud in it and the solenoid and spring both moving freely. According to the "how2 remove an EGR valve" there should have been two gaskets, mine only had the square one. Seems VX refitted it minus a gasket unless anyone knows any different.
    Put it all back together and went for a quick drive. All fine until it warmed up a bit then it started to cough, car with spanner back on then it cut out completely while driving! Pulled over and re started it then drove home. Was out for a drive for about a mile all in.
    Looks like will have to go to dealers and get them to read the code
    Mileage : 000
    Hope you get it sorted soon then "eh". Sorry I am not much help.
    Sunny Dartmoor
    Wish i could help Lee,but know nothing about the symptons you have,hope it gets sorted with minimal fuss........
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Went out this morning to start the car and it was lumpy as hell and not driverable so called the AA man out. He had a quick look, pushed on the plug for injector 3 and it started running ok. So legged it off to the stealers while it was still running and 1/2 way there it started to play up again. Anyways its now been tech2'd and the VX Tech says code points to the injector and it needs a modified wiring harness. So they have ordered the parts and it will be done tomorrow. Would do it myself but have to get to the airport tomorrow afternoon so the harness does not cure it then in theory its in the right place to be checked over again lol
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Trim : Elite with sports pack
    Engine : CDTi 150
    Mileage : 103000
    Glad you found out the problem
    & Sorry to here about your job
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    Yeah, hope you get it sorted but it looks like good old tech2 points in the right direction once again.
    The more i read about all the different code readers etc out there the more I feel it's better to get tech2 to do the job (IMO).
    Bri.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    It seems that the code is not being stored in the ECU memory for this fault as reported by TIS in the remedy. But saying that I have tried to read other codes with the U480 and it hasn't worked. It clears codes ok which is strange, but that was the main reason I brought it for anyways.
    Does anybody have a working code reader for full canbus cars????
    Northampton
    Engine : A20DTH
    Mileage : 88000
    check out this thread as well for the same issue
    http://www.vectra-c.com/forum/showthread.php?t=62925
  1. Urgent help needed, more signum problems :(
    By Shogun in forum Vectra C / Signum Troubleshooting
    Last Post: 29th September 2012, 20:45
  2. URGENT HELP: Zafira 2003 1.8XE poor running issue, not idling
    By merikiito in forum Engine & Drivetrain
    Last Post: 17th May 2012, 17:34
  3. Urgent Help Needed please, Signum Elite 2.0T CIM/Dash/Electrical Problems!!!!!
    By robs_gsi in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2012, 10:43
  4. Urgent Printer Problems Need Help
    By phil67 in forum The 'Off Topic' room
    Last Post: 25th March 2012, 21:41
  5. Urgent problems with Vectra
    By pacifica112 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2011, 21:59
