Results 1 to 10 of 11
Thread: Heater flap servo
    Mileage : 000
    Default Heater flap servo
    I have a suspicion one of the teeth on the heater flap servo mechanism has broken, as there is a clicking noise when I turn off the "recirc" button. Where is this servo and gears, and what do I need to remove to get to them. Any help would be much appreciated.
    Ste had to fix his Ed and started a thread on it - not sure if it included details of how to remove it etc. but maybe worth a search for his threads?
    Found it - http://www.vectra-c.com/forum/showthread.php?t=33018 - although no specific instructions on removal.
    Mileage : 000
    Cheers for the re-thread Duncan. But as you say no info on getting to the servo.
    Mileage : 000
    Any one replaced this servo them selves. Is it much of a job?
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    Hi Ed, got your pm but too lazy to reply there lol.. Not done one of these myself but will have a looksie in the usual place plus the Haynes manual and see what it says.. But right now its time for my pre-dinner snooze
    Regular Member Small Racer's Avatar
    Jan 2008
    Hampshire
    I had that on my Signum.
    If the thread/teeth have gone you need to fix it quick in this weather.
    The recirc will not be able to make its mind up if its closed or open and will keep trying to go one way or another - even when the car is switched off!!
    If you lock up the car and pop out now and again you may here the recirc click (clicking about 5 or 6 times per go - same sort of noise you get if you tap a pencil against a window in quick time) - and it just keeps on trying ....
    - which means its loading up the servo / motor and trying to open or close - result is battery drain!!
    VX fixed mine under warranty - did a disconect of the power line and then it took a few days to get the spare - only took the mechanic 3 cups of coffee (me drinking it !!) to sort - all done form inside the car behind the passenger glove box.
    Hope this helps.
    Mileage : 000
    Cheers Small Racer. I have been in touch with my VX dealer in Tamworth and have ordered the "servo motor". He said they used to have to change about 3-4 a week, but have not done any for a long time, he thinks they might be making the gears out of a better plastic. ( so if you have a newer Vectra you might not get this problem). So it looks like I will be having a go at it when I get the chance. Fingers crossed it is an easy job. Will keep you informed.
    Mileage : 000
    Small Racer . When you said you disconected the power line. I take it you removed the glove box and disconected the servo?? I might have to do that so it is inoperative till I get the part and the chance to change it.
    Mileage : 000
    Quote Originally Posted by plasma View Post
    From what I make out it should be straight forward. Just remove the glove box and the sevo is held on to the heater with Two screws. Well that is the theory. In practice it is probably like key hole surgury, we will see, any information will be helpful.
  1. Heater Servo Ticking
    By ed taylor in forum Bodywork & Interior
    Last Post: 7th November 2012, 10:26
  2. heater h/c flap motor
    By borderlinechris in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 09:14
  3. heater mixer thingy servo
    By toast in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2010, 10:49
  4. Servo pack / Heater / Relay - How annoying!
    By bobby_rstevens in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2008, 02:21
vectra c heater flap motor
resetting heater controll flaps on vectra c
heater servo vectra c
vauxhall vectra c heater servo
vectra c heater solenoid removal
vectra c servo mixer
vectra c heater flaps moving on their own
vectra c Heater servo & recirc motor are they linked
vectra c heater servo will it make other one click
vectra c climate control solenoid
clmate control vectra c mixer
vectra c climate control servo
vectra control heater control flap
Vectra c heater flap
vectra c heater control flap motor
vectra c heater flap fix
vectra c climate flaps reset
vectra c 2005 replacement recirculation flap actuator
heater servo what it does
2004 vectra heater servo
Vectra can heater servo
vectra c heater recirc clicking
replacement heater servo vectra
vectra c servo motor repair
