Thread: Rough Idling
    Surrey
    Default Rough Idling
    My 07 1.9 cdti has started running rough. There is a flat spot from Idle to 1000 revs. If I hold it at 1000 revs it is so lumpy it shakes right thru the car. Also at times it is making louder than normal Nocking noise. Any idea what this could be, I would like to go to the Dealers armed with some info to avoid being fobbed off with " Oh thats normal Sir" as is usually the case
    Difficult to accurately diagnose but it's sounding like it may be the DMF (dual mass flywheel).
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    If it is at least it will still be under warranty
    Surrey
    What are other symptoms of failing DMF as it does not have any rattles as described in other threads
    Well the judder that you describe is a main symptom - and if it's doing that out of gear then it's ruling out some other things.
    With it out of gear, if you rev it a bit so that it stops shaking and then lift your foot off and let the revs drop, do you get a bit of a judder as the revs drop back down to the idle range?
    If so, it is sounding like a DMF. The rattle/banging you mention happens in the more advanced stages of a DMF failure so the absence of those doesn't rule out a DMF issue.
    The DMF is a known issue, but you wouldn't think you'd have it already on an 07 car! But as it's under warranty best bet is to throw it back at the dealer and say you're pretty sure it's the DMF - a known problem on these cars.
    Surrey
    The nocking I referred to is more like a louder diesel Knock than a rattle, also if I sit with my foot on the brake pedal out of gear the shaking gets worse. Either way I think its off to the dealers
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Quote Originally Posted by iainm View Post
    Thread ressurection.....I will try this BOLD bit today!
    Regular Member Robsey's Avatar
    North East Cheshire
    25 Post(s)
    Trim : Energy
    Mileage : 150,000
    Did we get an outcome from November 2008...?
    Problem with a lot of threads on here is that most people get the car fixed, and just leave the thread open...
    It would help the rest of use to rule out or persue fault diagnosis on others experiences..
    Aug 2009
    Havant
    hmm mines just started to shake a little.... can't be flywheel on mine (I hope!) as it was changed 5k miles ago just before I bought it.
    it might have something to do with getting spray paint in the MAF on the weekend come to think of it....
  1. 3.2 Veccy C rough Idling
    By maleko in forum Engine & Drivetrain
    Last Post: 4th June 2012, 08:32
  2. 3.2 Veccy C rough Idling
    By maleko in forum Vectra C / Signum Car Chat
  3. siggy 1.9 cdti rough idling
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 11:47
  4. idling rough
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 16:21
  5. 2.2 idling
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:00
