Results 1 to 10 of 28
Thread: dpf
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Default dpf
    anyone on here removed the dpf off their vectra cdti? the reason why im asking is my vectra is using a bit more fuel than it should so im thinking the dpf is at fault,my local vauxhall dealer keeps a non dpf cat in stock but it is about £357 plus vat,im getting fed up with 31 mpg out of a diesel in urban traveling
    Regular Member shan's Avatar
    Before you go spending all that money. Get the dealer or somebody with a Tec2 to do a burn/regeneration on the DPF. And see if that helps.
    I'm not sure how you drive but it's best to give it a hammering every now and again this helps with the regeneration.
    I don't think you can remove the DPF without causing all sort's of issue's. Not 100% but I'm sure somebody will confirm this.
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Question
    can't remember who but some has. I think they removed it without removing it and shorting across by tricking the car to think it was still there and did someting with tech2. How much more fuel is it using than you'd expect? Is it the 1.9 with the updated DPF software you have that runs permantly?
    The last time my Signum was at the dealer's they said their was a recall for the DPF. But i never tuck it back in.
    When i fitted the quad's i got a guy to do a regeneration on the DPF while he was doing someother work.
    I'd speak to them and see if the recall is just the software update.
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    sorry for being thick but whats a DPF as i have a 1.9 cdti
    Diesel Particle Filter. It's on the 1.9 Vectra estate and 1.9 Signum.
    Possibly some other model's but i know not the hatch and saloon veccy.
    Nicking Ya Dinner.
    Quote Originally Posted by solorider View Post
    That only just under what mine used to do urban tbh.
    I get 30 from the V6- urban so not that bad really
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    im sure the recall was a software update and regeneration, when vauxhall removed dpf they change software, turbo and exhaust,
    There is apost somwhere that describes it in great detail. I think it regens every 30 seconds on the 1.9. They re-wrote my software in Japan when I had all the unitentified problems with it and it regen's now when it gets to 9%. Think it became the last software update for all V6's nationally.
