Thread: tyre repair????
    liverpool
    Default tyre repair????
    I just went to get my tyre repaired. it had a screw in it. I was told it can't be repaired as it had what looked like black dust/black sand inside of it. The bloke in national said i'd need a new one. I'm just a bit gutted as it was a brand new tyre.
    Can anyone telll me if this is true. That the tyre was useless because of this dust/sand stuff?
    The hole in the tyre must have only been 3-4 mm dia.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    did you drive it on a flat?
    Mileage : 000
    I don,t know about the sand stuff unless as said above, and you have damaged the sidewall. Where was the puncture as there is a limit to where it can be repaired.
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Shouldnt make a difference as far as I am aware.
    The only time a puncture hasnt been repairable on one of my punture's was whent the chap said that it was too close to the edge and rendered it unsafe.
    He did say that he could do it, but hold no resposibility.
    If I were you, try a "round the corner" type tyre garage's, the type that do cheap part worn's and see what they say.
    You may find that National just didnt want to do it ot wanted to sell you a new one.
    If the other places say it cant be done, then fair do's, but if they do repair it, make sure you find out off them that it is actually safe.
    The place I geta puncture done from usually drills where the puncture is before repairing it, to clean the edges and the puncture to ensure its a clean and safe repair.
    HTH!
    birmingham
    Engine : 3200
    i drove my old calibra about 7 miles with a flat(no spare wheel)....when the guy removed the tyre it was full of black dust from the rim eating the side wall,once this happens the tyre is scrap
    liverpool
    I had to back it off the slope it was parked on to allow me to change the wheel. Guess this could have damaged the side wall. I didn't think about it at the time and just took my rim away with me, leaving the old tyre at national. I should have taken it somewhere else but oh well. I now have a part worn Goodyear eagle on it to see me through till I can get a new tyre put on.
    Anyone know if goodyear eagle's are any good??? I assume so as its a goodyear.
    I'mnot sure were the postis but i'd like to add national in bootle to the poor service providers. took my wheel in at 9.30 thismorning and was told itwould take 1-1 1/2 hours. Went back at 12 and it hadn't been touched and i should give them another 1/2 hour. So I went back at 1 to find it needed replacing.
    lanark
    6 Post(s)
    Year : 2017
    you will find many an oppinion on the goodyear eagle is it the nct5
    May 2007
    West Yorkshire
    Just get a second opinion, National have KPI's to reach!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The black dust is the inner skin of the tyre that has come away due to being run under inflated or flat,the inner skin keeps the air in the tyre,if it's weakened you can get air leaking into the carcass of the tyre causing it to fail.The reason National say to replace it is partly a**e covering (if it failed and caused you to have an accident) and they are a business at the end of the day,the staff have to make a living.
    Regular Member djr69uk's Avatar
    Midlands
    yeah if the black dust is inside then that's part of the tyre wall disintegration due it is being run partially or fully flat. kwik fit wouldn't repair one for me like that and i knew the guy that worked there. at the end of the day it's a pain in the a$$ but is it worth the risk? a blow out on a motorway would cause you a lot more grief than a dent in the wallet.
  1. screw in tyre repair or not ??? pics inside
    By rob warrington in forum Suspension, Wheels & Brakes
    Last Post: 17th September 2012, 03:52
  2. Tyre Repair Help !
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2011, 23:42
  3. holts tyre repair
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2010, 10:18
  4. Tyre Puncture repair
    By Diet1985 in forum The 'Off Topic' room
    Last Post: 15th January 2009, 15:22
  5. Ever seen a tyre repair done like this
    By Leviathan in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 22:05
