Results 1 to 10 of 15
Thread: misty windows
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    Default misty windows
    the windows on my 2007 sri keep getting like a hazy film on them which can be seen when the sun shines on them use good quality glass polish etc car dry inside going to change pollen filter its dry (drain holes clear ) but a bit mucky....ANY IDEAS ANYONE
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Im getting the same mate any ideas off anyone would be great
    lanark
    6 Post(s)
    Year : 2017
    could be you need to change your pollen filter and check the drain holes arent blocked up with dead leaves etc
    If it's a hazy film, as opposed to condensation, then it's due to the 'vapours' given off by the plastic trim on the dash. All you can do really is keep giving it a regular clean with glass polish etc.
    Are you VXR Enough
    16 Post(s)
    Vehicle : VXR8 6.0 muscle Skoda Octavia VRS
    Trim : VXR8
    Engine : 6.0 V8
    if you use the air con or climate alot this can cause haze on the windows
    Surrey
    What setting is the vents on Face, screen etc?
    Regular Member stuee's Avatar
    witney near oxford ish
    do either smoke in ur car?? and if u have had a front screen replaced their could be a prob with the bond line inwich holds the screen in so water/moisture can get in just have look mate polish on interior glass can put a film on it where as a good window cleaner is the best i work for rac autowindscreens so we get to sort alot of this. however we use some of i think the best glass cleaner out its fantastic will work alot better than polish. im sure u will have 1 of our fitting centres near u so pop in with spray bottle and we will sort u some out. (for free) every1 loves free
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    mainly on screen setting... haze is on side windows to
    Surrey
    How long after a clean until it hazes again?
    I clean mine with a damp MF with a bit of Megs APC on it. I then use AG window polish.
    Regular Member david.aka.judas's Avatar
    Suffolk
    i get it as well - another vectra trait........
  1. Thoughts on Misty Morning / Misty Grey Colour?
    By puppet in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2012, 21:53
  2. Misty fog light
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 22:44
  3. Misty shine?
    By Stuarty in forum Detailing and Car Care Discussion
    Last Post: 17th December 2009, 15:59
  4. misty headlight
    By suggs1971 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2009, 20:53
  5. Misty Grey?
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2006, 12:59
