Results 1 to 10 of 13
Thread: Rear wheel bearing
    Regular Member barney's Avatar
    nottingham
    Default Rear wheel bearing
    My vectra booked in at the dealers next thursday.
    off side rear bearing is on its way out. It starts to drone at about 35mph
    The car has only done 16k on 54 plate.
    Has anyone else experienced this problem or am I just unlucky?
    Seems a short life for a wheel bearing barney.. Prob just bad luck mate..sealed for life unit I believe..
    Jan 2006
    Dalriada
    seems a very short life for the rear bearing.
    at least all covered by warranty
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    droning noise has also started coming from the back of my vectra 2.0 dti ls could this be bearings as well ?
    South East
    tyre esp. rears can create droning noise. Different road surfaces will make matters worse or better, this often shows its the tyres. The head mechanic tested mine and talked about rear tyre noise.
    Its not always as bad as it seems.
    Nr Cardiff
    I'll be damned! Driving up to Formby today I was thinking exactly the same thing. Droning from the rear of the car (the missus was at home!) that sounded just like a bearing on the way out!
    Only another 4k 'till the next service so it can wait. (34k on the clock BTW)
    nottingham
    Hi Guys
    I think you'll find its the rear tyres...because of the rear camber set up
    on the vec-c's it causes uneven tyre wear..
    If you swop the tyres front to rear you will find the noise stops.
    but then its noisey at the front.
    Bridgestones are bad for it because they are a fairly hard compound.
    Glasgow Scotland
    Quote Originally Posted by barney
    Hi Guys
    This thread is certainly getting my goat up?Went to the dealer with this problem in November to be told the brakes need deglazed .Yip basicly cleaned done this and still getting the whinning noise from the O/S rear?.The wheel has been thourghly examined for play and there is none.Its driving me mental knowing there is a prob and i know its there, What the F/C/U/K can i do
    Regular Member Paulmac07's Avatar
    Jan 2006
    Livingston (W Lothian)
    My O/S rear wheelbearing started droning after 20k, seems a bit too common to be coincidence?
    nottingham
    I have had both rear bearings replaced in the last four weeks!!!
    It didnt solve the the droning noise..
    The only thing that resolved it was by swopping the tyres round.
    front to rear.
    try it...it will solve your problems.
  1. rear wheel bearing
    By Billythebubble in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2011, 19:19
  2. Rear wheel bearing/hub help
    By daviem-rfc in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 23:38
  3. rear wheel bearing??
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 22:14
  4. Rear Caliper \ wheel bearing
    By dmcl in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2007, 22:23
