Results 1 to 10 of 24
Thread: Will 20in Rims Fit The Veccy C?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Will 20in Rims Fit The Veccy C?
    how much hastle will it be to up grade to 20"s
    lanark
    6 Post(s)
    Year : 2017
    think the vec can take up to a maximum of 20 inch but im sure someone will tell you for sure soon
    Yep, 20s will fit no problem and I don't think any arch adjustments etc. are even needed. Ian C has 20s and I think they went straight on.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    cheers duncan
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    20s will look wicked m8 but the tyres are not cheap
    Regular Member MrT's Avatar
    Near Durham
    Doesn't it also depend on the rim width? That's why Vxl talk about some of the Irmscher 20" rims needing arch work (not all though) - they'll add a couple of feet to the turning circle as well, compared to <18" as (and may suffer inner arch fouling as well as the visible wing). It's the limit, so is best to check carefully, especially if you've gone for a 45+mm drop.
    Dubs are an option on Insignia though - they seem to have gone up an inch or so across the range; SRi rides on 18" std, with 20" optional compared to 19" optional on Vec - just looking at the factory speccable stuff, like on Plus packs etc.
    Yep, exactly - I was going to say that in my reply but just kept it simplified.
    Yes, the specific wheel will dictate whether any arch work will be needed. The Irmscher ones Ian has I believe fitted straight on while others may need work due to offset and/or rim width.
    Near Durham
    Oh hell, there I go complexing things up again!
    I guess the right tyres would be something like 245/30R20, for which everyone's favourite Falkens (452) are about £150 each - not too bad, all things considered. Add a ton for Michelins, or £80 for Contis and things get less to the liking of a budget-conscious driver
    Regular Member hagga's Avatar
    kingswinford
    I've got 20 x 8.5 on mine with a et45 offset running 235/30/20 tryes. mines lowered 45mm too and have no probs, loads of clearance.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by MrT View Post
    found falken tyres on line for £585.58 from event_mobile_tyres price may vary dependin on where you live though,price is a fitted price
  1. Drosser Veccy B old hand Veccy C virgin
    By drosser in forum Introduce yourself.
    Last Post: 27th November 2012, 06:42
  2. Thermostat from a 1999-02 veccy onto a 2003-05 veccy?
    By Drazek in forum Engine & Drivetrain
    Last Post: 9th January 2011, 22:21
  3. VXR Rims 19" & 17" Design Rims
    By signumboy in forum Parts for sale
    Last Post: 21st April 2009, 17:24
  4. 20in i500 alloy wheels
    By ian_c in forum Quick Photo Album
    Last Post: 13th April 2007, 19:51
