Results 1 to 10 of 11
Thread: LED bulb flashing problem
    Birmingham
    Default LED bulb flashing problem
    I have replaced my standard sidelight bulbs (501 i think) with white effect led bulbs and as expected i get the light error in my dash.
    The bigger problem is for some reason when i either
    unlock my car at anytime of day OR
    turn the lights on then off OR
    lock my car
    the led lights flash once every second for about 10 seconds???
    In the dark this looks really dodgy & ill probably get pulled by a passing copper!!
    Any idea why the lights are getting power????
    Mileage : 000
    The Vectra,s electrics don,t like LED,s it affects the bulb warning message too. There have been several threads about LED,s not working proporly on the Vectra.
    Regular Member jared.ryder's Avatar
    Jun 2007
    NORFOLK
    Mine are doing the exact same mate, apparantly you can get resistors from maplin to wire across the side light wires that will solve the problem.
    Regular Member mushy2007's Avatar
    Liverpool
    Beacuse the circuit is getting checked for bulb failure mate.
    Surrey
    Yes because you have gone from a filament to a diode.
    Birmingham
    Quote Originally Posted by mushy2007 View Post
    nice one mate, that answer makes sense thinking about it. Ill have a look at the resistor the other guy mentioned.
    thanks again guys
    Birmingham
    Quote Originally Posted by jared.ryder View Post
    do you know what ohm resister is required? also what type or even better a internet link to the specific part?
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    I had the same with mine. But I drive with my sidelights on all the time so I did'nt worry about it although it was a bit annoying having to OK the bulb failure warning all the time
    Jun 2007
    NORFOLK
    bear wth me ill try get the link that was sent to me...
    Jun 2007
    NORFOLK
    If you go to maplins and buy 2 resistors (item L22R) and wire them across the s/light wires, they will cure your problems,well they have on mine, but you know how finicky a vec-c can be!
    this is the link i got sent hope it helps mate.
  1. LED tail lights problem flashing strobe
    By alek_vxr in forum Electrical & ICE (including SatNav)
    Last Post: 24th June 2012, 23:54
  2. HIDs bulb problem
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2012, 20:13
  3. bulb problem
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 15:46
  4. 3.2 vectra c idle problem eml light flashing
    By richie_davey in forum Engine & Drivetrain
    Last Post: 30th November 2008, 12:04
