Thread: K&N Filter and K&N Induction kit...
    Northampton, UK
    Default K&N Filter and K&N Induction kit...
    Can anyone tell me how they work and if these improve how the car works or runs?
    How easy are they to fit?
    How much should they cost?
    Cheers!
    cambs
    hi
    most go with the k&n panel filter
    induction kits are fine if you have a cold air intake pipe connected to it.
    you need more cold air to increase power as cold air carries more oxygen than warm air.
    k&n panel filter is about £45
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    try ebay for the panel filter about 40 quid plus postage,induction kits are ok if you have a v6 as they sound great but on any less of an engine it sounds like your mums stuck under your bonnet with a dyson trying to clean up.
    Northampton, UK
    Cheers guys
    Regular Member derby4life's Avatar
    North,Shropshire
    do they make much difference to the cdti 150
    soz by the way
    cambs
    hi
    the panel filter made a big improvement to my 1.8.
    took out the flat spots and a little bit quicker of the mark.
    you will get mixed views on improvement.
    some say it better and some say no differance.
    so it seams to be a try and see m8
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by mhvcbv View Post
    hi
    as above on my cdti mate, much better with the airbox mod along with it
    Midlands Mod Shop - NFFC.
    Northampton, UK
    Airbox mod??
    Trim : Get a
    yes mate it is in the how2 section, just remove the inner lower trumpet so it allow's more airflow, and when done disconect the battery for about 15 - 20 min's to reset the ECU then the car will re-learn the new parrameters,
    edit - link below
    http://www.vectra-c.com/forum/showthread.php?t=54506
    cambs
    yep did the airbox mod and the shorter air intake pipe aswell.
    i think it one of the first mods that most people do as its cheap
  1. K&N filter or induction?
    By chrissy white85 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 13:41
  2. Air filter or Induction Kit???
    Last Post: 12th October 2012, 21:26
  3. Induction kit and Air filter
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2009, 00:00
  4. Air induction v air filter
    By johncharles in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2009, 15:23
  5. Which air filter/induction kit?
    Last Post: 9th July 2007, 17:12
