Thread: front fog bulb warning
    Regular Member hagga's Avatar
    kingswinford
    Default front fog bulb warning
    Hi peeps, Have just started to get front fog lamp blown msgs. Sometimes its just the left or sometimes both but both lamps are fine...any ideas?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Maybe the harness is not plugged incorrectly. Have you had the front bumper of recently? Follow the harness back from the two fog lights and you will see where the plug is (the harness also includes the outside temperature sender)
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    On mine the terminals looked slightly corroded,so used some electrical contact cleaner and i've had no problems since.
    Jul 2006
    Mexico
    I have faulty bulbs messages every now and then (3-4 times a year)....and yes bulbs are fine...usually I get it after turning on / off the lights...I think its a glitch on the system....not the bulbs or the "sockets"
    I learned how to live with them
    Regular Member david173's Avatar
    Dec 2005
    Dumbarton, Scotland
    I had this problem temporarily last winter, i put it down to the cold weather and a loose connection, but i've had it on constantly for months this year!! Bulbs are working fine, sometimes the left one is out then after a few seconds warming up they both go on. Getting sick of the warning every time i start the car, and the constant bulb symbol in the speedo display area, grrr! I have however had my bumper off last year.... so i dunno wats the deal with it
    New Member finkbrau's Avatar
    leicestershire
    Hi
    got a similar problem. Get warning in dash that light out. Had a slight meeting with the rear of a fiesta months ago and now get a warning light on. Checked lights and front n/s bulb out. Tapped the headlamp lens when and the light comes on a warning disappears. Oddest thing is that when the bulb is off (side ligths switched on) the same n/s indicator bulb illuminates constantly. tap lens and indicator goes off and side light returns - any ideas (bumper also off as was replace due to a slight buckling!!). Headlamp not replaced but took some impact from rear of the ford thing.
  1. bulb warning
    By dodus in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd May 2012, 17:08
  2. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  3. Warning Bulb gone ?
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2010, 01:04
  4. bulb warning lmp
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2009, 13:30
  5. Bulb Warning
    By rider in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2006, 19:51
