Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: Vectra 'Injector Plug' Issue, it's Like Driving a Bouncy Castle!
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Default Vectra 'Injector Plug' Issue, it's Like Driving a Bouncy Castle!
    Im trying to find out how to get hold of a 'modified injector plug wiring harness kit', coz apparently this will help fix my juddering problem!
    Does any1 know if a 'modified injector plug harness' has been fitted to the Facelift model, coz if so ill find a breakers that has a Veccy then take the harness off?!
    EVERYWHERE
    Have you posted this in the 'engine & drivetrain' forum ?
    I wouldn't be removing any harnesses without first confirming the problem.
    Maybe just a bad injector ? Is your car remapped etc ?
    Quote Originally Posted by diesel dog View Post
    Now moved to there from the diesel tuning section as more likely to get viewed/replies.
    Jan 2008
    South Wales
    Soz Dunc I didnt realise I had put it in this section, doh lol!
    Jan 2008
    South Wales
    No its not remapped but I did have a tuning box but thats been off for over a month!
    Im pretty positive its my 3rd injector plug, coz every time I clean the connections its fine for a day or two then slowly starts to judder again. Iv just given the pins another clean and cable tied it in place coz there was a little play in the plug! Im looking to find an 'injector plug rework kit' to fix this issue??
    EVERYWHERE
    Is the car still in warranty? As it was a common problem on older cars and maybe,just maybe,you'll get a little sympathy from Vauxhall if it's just out of warranty.
    Wasn't there a recall for this?
    Jan 2008
    South Wales
    Na no warranty left, my car is a 2004/54 plate, is expired september 13th 2007!
    As far as im aware I dont think there was a recall for this issue, well not that iv heard of anyway. Does any1 know if there was or how I can find out?
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    defo no recall on this, just a modified loom. Will ask at Vx tomorrow when i'm in there ordering me rear heated seat pads and stuff
    Jan 2008
    South Wales
    Quote Originally Posted by plasma View Post
    Cheers plasma! I went to FRF my local Vx dealer last tuesday and asked about getting a new injector loom, he just looked at me stupid then searched the system and found nothing! He told me to check the loom on my car for a part number but I cant find anything?
    I have a part number here for what I think is the 'Modified Injector Wiring Loom', is this what I need:
    Part Number - 93189918
    Kat Number - 62 86 769
    Jan 2008
    South Wales
    Default Modified Injector Plug Wiring!
    Popped into FRF Vx in Bridgend South Wales today armed with this Part Number: 93189918 (Kat Number: 62 86 769) and hey presto they had them in stock, woo hoo!!! All I need do now is get under the hood tomorrow, take the faulty plug off the injector, cut the old wire and solder this new bad boy on, fingers crossed thats all there is 2 it, hmmmm
    I wont need all the wires by the way, just the 2.5mm ones and there r 2!
  1. injector issue
    By dubdub155 in forum Engine & Drivetrain
    Last Post: 17th December 2012, 18:19
  2. injector #3 Issue?
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 10th February 2009, 14:23
  3. Bouncy Castle
    By redbullkid in forum Comedy & Humour
    Last Post: 14th September 2006, 11:10
vectra c injector wiring
vectra 1.9 cdti injector wiring
vauxhall vectra injector wiring loom
vauxhall vectra 1.9cdti injector wiring loom
vectra c injector connector
z19dth injector connector
vectra c injector loom
motor z19tdh inyector conector
vectra c injector plugs
vectra c 1.9 cdti 150 injector open circuit
z19dth injector.plug polarity
vectra injector plug wires
deisel injector plug vectra
vauxhall vectra cdti injector plug connectors
vauxhall vectra 1.9cdti loose injector plug
vectra 1.9 cdti injector wire
vectra injector wires fault
1.9 cdti Vauxhall signum injector plug
how to replace injector plug 1.9 cdti signum
vectra c 1.9 cdti injector plug replacement
z19dth injector plug wire
z19dth injectoctor plugs
vectra c p0201 p0202
Z19dth injector wiring fault
astra 1.9 cdti 8v injector plug issue
