Thread: Knackered dash
    Regular Member Karl's Avatar
    Sunderland
    Default Knackered dash
    OK, good start, 4 days in with my new Vectra and the dash has decided to throw a wobbler, it doesn't work, at all.
    No rev counter, no mileage, no speedo, no lights you get the idea.
    The weird thing is the two lights that do work are the door open light (on permanently, even when car off and locked) and the orange alternator(?) one that comes on when you start it up.
    Looks like a trip to the dealers tomorrow morning, its kinda disconcerting not knowing what speed you are doing.
    Sunderland
    mmmm, strange, hit the trip button and all now ok, will have them check it Monday when it has it's (overdue) service
    Surrey
    Could be a loose plug and when you pushed the trip reset you pushed the cluster enough to make a good connection.
    Regular Member Robbie69's Avatar
    it is a loose plug, take the clocks out and give it a good push in, happened to mine too, OK now though!
    Sunderland
    nah, aint a loose plug, first thing I checked. God knows what it is, don't really care, that's 150 miles NOT on the mileometer.......
    Jul 2006
    Mexico
    CIM module maybe or the famous ABS plug doing his famous bad connection.....unplug the ABS plug check for dirty terminals and replug...that cure my funny instrument panel.
    HTH
    Regular Member sanjeevgangar's Avatar
    bedfordshire
    Try 2 reset the computer with pressing that round button in speedo meter (don"t know what its called) press it for about 10-15secs until its change the numbers and endup on 0000, It worked for me once when I found the similiar prob like urs.
  1. ECU is knackered
    By dhwigston in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 16:09
  2. My DPF is knackered! Help!
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 6th March 2012, 15:46
  3. I'm knackered!
    By AJA in forum The 'Off Topic' room
    Last Post: 10th February 2008, 15:48
  4. I'm Knackered
    By AJA in forum Comedy & Humour
    Last Post: 13th February 2006, 10:45
