Thread: 1.8 VVTi engine, lack of power.
    derby
    Default 1.8 VVTi engine, lack of power.
    I have a 1.8 in a Signum 56 13.000 on th clock. Maybe it's just me but my car seems very very sluggish. from a standing start everything on the road accelerates away from me. you name it and I'll guarantee it will leave me standing. Also the gear change isn't as smooth as other cars I've had, almost like there is a flat point between 2nd and 3rd also sometimes hesitates when pulling away in 1st. Does anyone else suffer this kind of performance from the 1.8? maybe it's normal and I'm expecting too much from a small engine in a big car. What do you think?
    Regular Member shan's Avatar
    Mine's a 1.8 mate and that's it I'm afraid. The signum is even heavier as well.
    You can do the airbox mod, K&N filter and air intake mod. That helps.
    I recently had a new clutch and flywheel fitted as it's a known issue with the 1.8, under warranty
    Have a read of this. http://www.vectra-c.com/forum/showth...ddering+clutch
    derby
    Thanks for that Shan. Had clutch and flywheel replaced a month ago, stopped the judder but didn't improve the smoothness of gear change. Will modifying the air intake affect the warranty?
    Quote Originally Posted by mikeopolo View Post
    I would not think changing the intake will void the warranty. I'm quite sure the VX mec's would never even notice. You don't have to get any service work done at VX anyway to keep the warranty good.
    derby
    Ok will check it out. Gotta be worth a try, can't stand the embarrassment much longer!!!Cheers.
  1. What is meant by 1.8 VVTI? is the vvti engine better or worse?
    By Deann in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 11:19
  2. lack of power
    By apache653 in forum Engine & Drivetrain
    Last Post: 6th February 2011, 20:18
  3. Cdti lack of power engine sluggish
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 19th January 2011, 16:07
  4. 1.8 vvti, lack power low revs?????
    By mitch in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2010, 08:53
  5. Help! lack of power, engine cut out not even hazards working!
    By coppjoe in forum Engine & Drivetrain
    Last Post: 23rd February 2010, 17:02
vauxhall 1.8vvti lack of power
