OOO I HOPE on that, i will check tomorow but the temperature outside is -5 its freezing and more than 10cm of snow let wait and see ,thnx cheers
hi MAT's everything seem's fine today a just drive for a minute and the lights came OFF and ABS & TC are working GOOD so thnx i realy appreciate for everything thanx for help guy's cheers .....
Glad your motor is ok now. Looks like the snow might have "shorted" the ABS and has dried out now. Keep an eye on it just incse there is a fault with it, but I think you will be ok now.
hi mate same happened to me,came on then went out did that for awhile then came on permantly if lights are on be careful you have no abs i went straight over a round about i messed with a sensor on the inner wheel arch of drivers side it sits in a clip it had come out put it back in never came on again,if those lights come on mate please drive carful in this weather as the car locks up and skids and you have no traction either
yep i will be carful thank you mate, i hope never came back ON in this weather hehehe cheers
I had this problem with my pre facelift when i got stuck in the snow as the system throws a wobbly because your wheels are spinning like mad mine went out after i re started the car and drove 50 yds also just remembered the same thing happened with the estate at the rolling road day same problem with traction.hth
