Thread: Sump plug was a bit tight!!!!!
    preston
    Default Sump plug was a bit tight!!!!!
    Just changed oil on my 1.9cdti and couldn't get the sump plug off at all. Mega tight. Started to shear the hexagon so ended up chiselling the thing off ! See pic's of my 'specialised tooling' ! Think I'll get one of those tubes that suck up oil through the dipstick tube next time.
    Belfast
    Pretty standard - the new plugs are a different metal and don't shear off. The new type are yellow anodised.
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    look carefully.... is your sump stating to crack it looks like it to me
    Blantyre
    Dont use one of those tubes mate, i did on my last car and the lot didnt get taken out, so when i filled it up with the recommended qty of oil............ dip stick was showing 3-4 cms above max line
    Keep to the sump plug
    preston
    What appear to be cracks are typical lines you get on an alloy casting, the sump is fine
    East Midlands
    It's usually caused by the grease monkeys using air tool to tighten the plug up after oil change ..can't think why they do this..all it needs is nipping up.
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    The 2nd pic reminds me of the thearter in a NHS Hospital! lol
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Sump Plug
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th February 2011, 18:55
  3. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
  4. Sump Plug Nut
    By si_hoss in forum Engine & Drivetrain
    Last Post: 22nd February 2010, 18:32
  5. getting the sump plug out ????
    By Nickzx6r in forum Engine & Drivetrain
    Last Post: 6th October 2007, 07:55
